The Q&A is closed for the 2021-2022 season. Any rule changes or clarifications pertaining to the 2022 VEX Robotics World Championship will be included in the April 5 Game Manual Update. Teams attending VEX Worlds who wish to pre-submit questions for the driver's meeting should have received a contact form via email; if not, please contact your REC Foundation Team Engagement Manager for more information.
سؤال و: VRC 2021-2022: Tipping Point
1051: Trapping, avenue to escape
Trapping – A Robot status. A Robot is Trapping if it has restricted an opposing Robot into a small, confined area of the field, approximately the size of one foam field tile or less, and has not provided an avenue for escape. Trapping can be direct (e.g. pinning an opponent to a field perimeter wall) or indirect (e.g. preventing a Robot from escaping from a corner of the field).
It is possible to confine a blue robot to the area between the red platform and two red robots. In this case,
- would the path to platform be considered an avenue to escape when there are more than 30 seconds remaining in driver control?
- would the path to platform be considered an avenue to escape when there are less than 30 seconds remaining in driver control? If so, would this be considered to be not interfering with gameplay(one additional elevated robot for blue) or interfering with gamplay(DQ for red)?
- Would the answer to the previous two questions differ if the robot is not capable of climbing platforms/tipping the platform?
- would the "approximately the size of one foam field tile or less" be strictly one or less, or could it be more than one foam field tile? If more, what is the upper limit that a robot is no longer considered being trapped?
![[Example Image]](https://events.vex.com/storage/markdown/uploads/qKn1x3nkGUzJqYG9Z2PmYwMuqstrmc7dPQFjNg5r.png)
![[Example Image]](https://events.vex.com/storage/markdown/uploads/YbLLJhK58RKNIesrvB9yS4Pg9jI3DuWzUEcF3BTL.png)
The answer to all of these questions is "no".
The upper limit is "approximately the size of one foam field tile or less". The word "approximately" is intentionally used, instead of "strictly", to allow for Head Referee discretion in the context of a Match (i.e. it would not be reasonable to expect Head Referees to measure and track exact distances during this type of dynamic interaction).
