Skip to Main Content
The Q&A is closed for the 2021-2022 season. Any rule changes or clarifications pertaining to the 2022 VEX Robotics World Championship will be included in the April 5 Game Manual Update. Teams attending VEX Worlds who wish to pre-submit questions for the driver's meeting should have received a contact form via email; if not, please contact your REC Foundation Team Engagement Manager for more information.
سؤال و: VRC 2021-2022: Tipping Point
إرشادات الاستخدام جميع الأسئلة
1055: Ring Preload Starting Position Touching Mobile Goal
Jonathan Roberts (Event Partner)
15-Feb-2022
The attached image, taken from a recent event, shows a robot that is using a mobile goal as leverage to hold up a Preload ring at the start of a match while in contact with the same ring. [Example Image]
SG1 iii. states
All Preloads must not be in any positions that would be considered Scored if the Robot were not present.
Scoring Figure 1 on page 18 of ver 2.4 of the game manual shows the following images and makes mention the ring touching the goal would be scored if it is not in contact with a robot. [Example Image]
Based on these two items, would this be considered an illegal starting position?
تم الرد بواسطة committee
As you have noted, the Ring in the attached image would not be considered Scored, because it is contacting a Robot. If the Robot were not present (i.e. were to instantly "vanish"), the Ring would still not be in a Scored state.
Therefore, yes, this would be considered a legal starting position.
