The Q&A is closed for the 2021-2022 season. Any rule changes or clarifications pertaining to the 2022 VEX Robotics World Championship will be included in the April 5 Game Manual Update. Teams attending VEX Worlds who wish to pre-submit questions for the driver's meeting should have received a contact form via email; if not, please contact your REC Foundation Team Engagement Manager for more information.
سؤال و: VRC 2021-2022: Tipping Point
814: GPS Field Code Strips for Qualifying Events
The Game Manual update on June 29 included the following modification of the competition field for the skills challenge
In Programming Skills Matches, the VEX GPS code strip must be installed on the field. This field modification will be recommended for all events beginning August 1, and required for all events beginning October 1.
If an event designates a field for both programming and driving skills challenges, can the GPS code strip stay on the field during driving skills matches?
If an event designates a field for both Skills Challenge and Competition Matches (such as allowing skills challenge before matches start), can the event keep the GPS code strip on the fields during qualification & elimination matches?
Can an event place GPS field code strips on fields for use only for competition?
If a GPS field code strip is present on a field, is a team always permitted to use it, even during competition matches?
The note which is quoted in your question is only intended to address Code Strip requirements for Programming Skills Matches. There are no requirements set forth by the Game Manual for other types of Matches; that is to say, it is at the Event Partner's discretion, just as there is no requirement in the Game Manual for a field to be on the floor vs on a raised platform.
Hopefully, that context helps to explain the following answers.
- If an event designates a field for both programming and driving skills challenges, can the GPS code strip stay on the field during driving skills matches?
Yes, although there is no requirement to do so.
- If an event designates a field for both Skills Challenge and Competition Matches (such as allowing skills challenge before matches start), can the event keep the GPS code strip on the fields during qualification & elimination matches?
- Can an event place GPS field code strips on fields for use only for competition?
Yes.
