Skip to Main Content
The Q&A is closed for the 2021-2022 season. Any rule changes or clarifications pertaining to the 2022 VEX Robotics World Championship will be included in the April 5 Game Manual Update. Teams attending VEX Worlds who wish to pre-submit questions for the driver's meeting should have received a contact form via email; if not, please contact your REC Foundation Team Engagement Manager for more information.
سؤال و: VRC 2021-2022: Tipping Point
إرشادات الاستخدام جميع الأسئلة
869: Rings on Alliance Goals that are out of the field
386E
25-Sep-2021
If an alliance goal falls out of the field, some of the rings stay on the pole or in the base, and it occurs during the last thirty seconds of the match when scoring objects are not returned to the field, would those rings still count for points?
In this hypothetical scenario, the two main questions are: -Do the rings get removed the moment it falls out of the field -Do the rings count as points if the goal is not inside the field
For the first question:
According to <SG9>, scoring objects will be returned to the field in a non-scored state, and scoring objects will not be returned during the last 30 seconds. Additionally, in LRT matches scoring objects will not be returned to the field regardless of how much time is remaining.
<SG9> doesn't specify the state of the scoring objects while outside of the field, just that when being returned that the rings are set down separately. It doesn't confirm that the rings would be left on if its during the last 30 seconds, but it doesn't say they wouldn't.
For the second question:
In the Scoring Notes, it specifies that "Rings which are Scored on/in an Alliance Mobile Goal are worth points for that color Alliance, regardless of where the Alliance Mobile Goal ends the Match"
This would suggest that if the rings were left on the goal, that they would count for points.
Ultimately, having these rings count for points would not benefit anyone strategically, as <SG9> also states that Scoring Objects cannot be intentionally removed from the field, but with robots regularly climbing the platform while holding mobile goals, this scenario may not be too rare and it could be match affecting.
تم الرد بواسطة committee
No.
Yes, to a feasible extent (understandably there will be a few seconds' delay while a referee walks over to the fallen Mobile Goal).
No.
