The Q&A is closed for the 2021-2022 season. Any rule changes or clarifications pertaining to the 2022 VEX Robotics World Championship will be included in the April 5 Game Manual Update. Teams attending VEX Worlds who wish to pre-submit questions for the driver's meeting should have received a contact form via email; if not, please contact your REC Foundation Team Engagement Manager for more information.
سؤال و: VRC 2021-2022: Tipping Point
878: Manual Update Definition of Scored Contradiction
Scoring Note 1 states:
Rings can be Scored in Mobile Goal Bases, or on Mobile Goal Branches. In order to be considered Scored in either position, a Ring must first meet the following prerequisite criteria:
• Not contacting a Robot of the same color Alliance for which the Rings would receive points
• Not contacting any Field Elements, such as gray foam field tiles, the Platform, or the field perimeter
• Not contacting any Rings which are not considered Scored (i.e. Rings which are contacting a Robot or a Field Element)|
Emphasis mine.
On page 18 of the game manual near the bottom Scoring figure 5 is shown, which depicts a stack of rings on a mobile goal that exceeds the height of the branch, resulting in the top few rings not being scored (I have attached this image to this Q&A)
The caption for this figure reads:
Only the highlighted Rings would be considered Scored, as they are the only ones fully or partially encircling the Mobile Goal Branch.
From my understanding of Note 1 bullet point 3, none of the rings in Figure 5 should be considered scored, since the rings on top which are not considered scored are contacting the rings beneath them, causing a chain of not scored rings which results in all of the rings not being scored. A very similar situation is show in in Figure 3 and Figure 2 that demonstrates this concept. Despite this, Figure 5 states that the rings below the unscored rings are, in fact, scored, which seems to be a contradiction. Can the GDC please clarify if the green shaded rings in Figure 5 are not scored as the Note states they are not or if they are scored as the caption say they are? Thank you.
Thank you for bringing this to our attention.
The intent of the figure was primarily to demonstrate what was meant by "encircling a Mobile Goal Branch", by depicting a scenario where Rings did not meet this definition.
Your interpretation of Note 1 is correct; if this situation were to actually occur in a Match, none of the Rings would receive points, as they are all transitively contacting the top un-shaded Rings. We will be sure to update this caption in a future Game Manual update to make this distinction more clear.
