Skip to Main Content
The Q&A is closed for the 2021-2022 season. Any rule changes or clarifications pertaining to the 2022 VEX Robotics World Championship will be included in the April 5 Game Manual Update. Teams attending VEX Worlds who wish to pre-submit questions for the driver's meeting should have received a contact form via email; if not, please contact your REC Foundation Team Engagement Manager for more information.
سؤال و: VRC 2021-2022: Tipping Point
إرشادات الاستخدام جميع الأسئلة
881: Clarification of Set Up Placement for the Tall Middle Goal for Neutral Zone
41091A
7-Oct-2021
Our team has noticed after working on some Autonomous Programs that the tall Neutral Middle Goal placement is different from several Vex posted sites. Please clarify the placement and orientation and which document is authoritative.
I'm also an EP and we are hosting an event on Oct 23. I already have printed field reset papers for volunteers using the light gray with foam tiles lines shown on the bottom right side of the image attached. Just wanted to note that this image is easier to follow for volunteers to decide the correct placement.
[Example Image]
G4
تم الرد بواسطة committee
Edit 2021-12-07: The v2.2 Game Manual update included the following “red box” addition to rule <G19>. We sincerely apologize for any inconvenience and confusion caused by this inconsistency.
Prior to version 2.2 of the Game Manual (released December 2021), there have been conflicting interpretations of the correct Mobile Goal rotation in the official game documentation. The layout defined in Figure 20 above, and Appendix A, in version 2.2 (or later) of the Game Manual is the only correct variation. This layout takes precedent over any other variations found elsewhere, such as other figures, websites, videos, etc that were created prior to December 2021.
Here are some ways to visualize the correct orientation, using the V-shaped vision target as the “front” of the heptagon, and the rectangular vision target as the “back” of the heptagon:
• The Alliance Mobile Goals that rest on the Platforms are “pointing towards” their respective Platform
• The Alliance Mobile Goals that begin on the AWP Line are “pointing towards” the Neutral Zone
• The outer two Neutral Mobile Goals are ”pointing towards” the field perimeter walls
• The center Neutral Mobile Goal is “pointing up”, when viewed from the audience perspective, or “pointing left” when viewed from the red Alliance Station
