Skip to Main Content
The Q&A is closed for the 2021-2022 season. Any rule changes or clarifications pertaining to the 2022 VEX Robotics World Championship will be included in the April 5 Game Manual Update. Teams attending VEX Worlds who wish to pre-submit questions for the driver's meeting should have received a contact form via email; if not, please contact your REC Foundation Team Engagement Manager for more information.
سؤال و: VRC 2021-2022: Tipping Point
إرشادات الاستخدام جميع الأسئلة
888: Neutral Mobile Goal Scored but touching outside floor
248A
20-Oct-2021
In two recent events, I have seen the tall netural mobile goal legally placed on the platform and fall with the branch going outside the field of play - touching the floor outside the field. 1) The first (pictured) was not on a balanced platform, but it technically meets all of the definitions for being scored in the Home Zone (Scoring Notes 3) since the base was in the 3D of the Home Zone. 2) The second (not pictured) was on a balanced platform while not contacting any other Field Elements, such as foam field tiles or the field perimeter. So, again technically meets all of the definitions of being scored and elevated (Scoring Notes 3 and 6 and definition of Balanced).
The common sense rule may come into play since it is touching the floor outside the field of play ... but if that does and you declare the game object outside the field of play, should it be placed back in the field of play (if not within 30 seconds) SG9? And if so, where would you put it as the "the location nearest the point at which they exited" is on the platform?
[Example Image]
تم الرد بواسطة committee
The full text of SG9 reads as follows:
<SG9> Keep Scoring Objects in the field. Teams may not intentionally remove Scoring Objects from the field. While Scoring Objects may accidentally leave the field, doing so intentionally or repeatedly would be a violation of this rule. Scoring Objects that leave the field during Match play, intentionally or unintentionally, will be returned to the field at the location nearest the point at which they exited. Referees will return the Scoring Object to the field when it is deemed safe to do so, at the leisure of the referee.
Minor violations of this rule that do not affect the Match will result in a warning. Match Affecting offenses will result in a Disqualification. Teams that receive multiple warnings may also receive a Disqualification at the Head Referee’s discretion.
If a Mobile Goal leaves the field, any Rings that were Scored in the Mobile Goal Base, or on Mobile Goal Branches, will be returned to the field in a non-Scored state, on the field tile closest to where they exited.
Note: During the last 30 seconds of the Match:
• Any Scoring Object that leaves the field will not be returned.
• If a Scoring Object is leaving the Field (as determined by the Head Referee), but is deflected back into the field by a Drive Team Member, field monitor, ceiling / wall, or other external factor, it should still be considered “out of the field” and removed by a scorekeeper or Head Referee. If the redirection occurred due to contact with a Drive Team Member, it will be at the Head Referee’s discretion whether <G9> or <SG9> should apply.
The intent of the Note's second bullet point is to say that as soon as a Scoring Object makes contact with anything outside of the field, it should be considered "out of the field" and dealt with accordingly.
Therefore, the Mobile Goal in the attached image should be considered "out of the field". If the contact occurred during the last 30 seconds of the Match, it should be removed from the field. If it cannot be removed from the field safely and/or in a timely manner, it should simply be considered "not scored".
If the contact occurred before the last 30 seconds of the Match, then the Mobile Goal should be returned to a field tile closest to where it exited. It should not be returned to a Platform.
