The Q&A is closed for the 2021-2022 season. Any rule changes or clarifications pertaining to the 2022 VEX Robotics World Championship will be included in the April 5 Game Manual Update. Teams attending VEX Worlds who wish to pre-submit questions for the driver's meeting should have received a contact form via email; if not, please contact your REC Foundation Team Engagement Manager for more information.
سؤال و: VRC 2021-2022: Tipping Point
942: Does using 393 motor controllers to control LED Strips violate rule R31c or R6b?
Hello,
Our team has wired up 5v LED strips to work with the vex v5 system. The LEDs are being run by the motor controllers for 393 motors, with LED cabling soldered to the output wires, and the neutral spliced into one of the 3 wire ends. Is this Legal? Would this be considered a violation of rule R13c, or R6b?
Thanks!
Here is R13c for reference: “VEX electronics may not be used as non-functional decorations”
And R6b: “Electronics from the VEX Cortex control system are not permitted. This includes the VEXnet Joystick, VEXnet Partner Joystick, VEX ARM® Cortex-based Microcontroller, VEXnet Key 1.0 and 2.0, 2-Wire Motor 393, and any other electronic components which are not compatible with the VEX V5 system”
Thank you for quoting the relevant rules in your question. Per R13-c and R6-b, no, this would not be legal.
