Skip to Main Content
Oficiální otázky a odpovědi: VEX V5 Robotics Competition 2026-2027: Override
Pokyny k použití Všechny otázky
3216: Questions On Plasma Cutters
25424X
22-Aug-2026
A teammember is wondering how plasma cutters are considered when referencing rule R27.
R27 states that, “Metallurgical modifications that change fundamental material properties, such as heat treating or melting, are not permitted.” and if plasma cutting works by melting metal, “As the gas passes through the electric arc, the energy rapidly heats it, causing ionization. This transforms the gas into a high-velocity stream of plasma, which can reach temperatures exceeding 20,000 degrees Celsius (36,000°F). This jet is directed toward the metal workpiece, melting the material almost instantly at the point of contact.” while also causing a heat affected zone, “The heat affected zone (or simply HAZ) is something that occurs when metal is subject to high temperatures,” at the same time, then is plasma cutting illegal based on rule R27?<R27> Sources: VEX rules, content.vexrobotics.com/docs/2026-2027/override/files/override-v1.1.pdf Plasma melting and heat source, engineerfix.com/how-does-a-plasma-cutter-work-the-science-explained/ HAZ source, fractory.com/heat-affected-zone-causes-effects-reduction/
R27
Zodpověděl committee
17-Sep-2026
Plasma cutting is permitted under <R27> as a physical modification (cutting). <R27> clause B is mainly meant to prohibit intentional alteration of material properties (e.g., heat treating to increase hardness/strength), rather than incidental heating that occurs during a cutting process.
