Q&A
VEX V5 Robotics Competition 2026-2027: Override
Welcome to the official VEX V5 Robotics Competition Question & Answer system, where all registered teams have the opportunity to ask for official rules interpretations and clarifications. This Q&A system is the only source for official VEX V5 rules clarifications, and the clarifications made here from the Game Design Committee (GDC) are considered as official and binding as the written Game Manual itself.
Please review the Q&A Usage Guidelines before posting. This system is only intended for specific VEX V5 game rules questions.
Indexação
3159: Interaction Between Alliance-Assisted Recovery of a Tipped Robot and Defensive Play
29-May-2026
GG14 GG15 GG17
<GG14> <GG15> <GG17>
Override permits Robots to expand vertically 50", which may result in more tipped or incapacitated Robots than in some previous games. Consider the following scenario:
Blue1 Robot tips over on its own and becomes unable to continue normal gameplay. Its Alliance partner Blue2 attempts to right or otherwise assist the tipped Robot so that it can resume participation in the match. Red 1, an opposing Robot, repeatedly interferes with Blue 2 assisting Blue 1's recovery attempts. The interaction does not involve damage, Entanglement, or a violation of holding 3 count holding rule.
Given Rule <GG14> ("Don't destroy other Robots. But, be prepared to encounter defense."), Rule <GG14a> ("V5RC Override is intended to be an Offensive game..."), Rule <GG15> ("Offensive Robots get the benefit of the doubt when judgment calls are required."), Rule <GG17> ("No Holding for more than a 3-count"), and the Game Design Philosophy section emphasizing teamwork and offensive gameplay, does the Game Design Committee consider preventing an Alliance from restoring a tipped partner to be normal Defensive play? Or is there is there any point at which an opposing Robot whose primary objective is preventing the recovery of a tipped Robot would be viewed differently than normal defensive play?
If alliance-assisted recovery is an intended gameplay strategy, should a Robot actively attempting to restore an Alliance partner to functionality be considered an Offensive Robot for purposes of applying Rule GG15?
Thank you for your consideration. I have included an example of this occurring in PushBack.
https://www.vexworlds.tv/#/viewer/broadcasts/qualification-matches-research-q7f0pbswphlwiosmhe5j/usyylbvefmrtenb4umff
Match 56 - Timestamp mark 2:23:05
Respondido por committee
Robots should avoid playing defense or otherwise interfering with opposing Alliance Robots involved in an attempt to recover a tipped opposing Robot. This falls outside the bounds of "normal" defensive gameplay.
A Robot interfering with the recovery of a tipped opposing Robot is instead engaging in destructive defensive gameplay, and runs the risk of incurring a <GG14> Major Violation for intentional and/or egregious tipping, damage, etc.
3192: GG16 Clarification
27-Jul-2026
GG16
Suppose a Blue Robot is legally driving near the opposing Red Stake. A Red Robot intentionally or strategically pushes the Blue Robot into the Red Stake, causing the Stake to collapse. In this situation, the Blue Robot did not intentionally contact the Stake. The Blue Robot was attempting to escape, but contact occurred because the Red Robot continuously pushed and forced blue bots into the Stake.
How should this interaction be ruled?
More specifically:
  1. Does it matter whether the Red Robot intentionally pushed the Blue Robot into the Red Stake, or is the final result—the Red Stake collapsing—alone sufficient to determine the ruling?
  2. If the Blue Robot had no reasonable opportunity to avoid the contact because the Red Robot continuously and intentionally pushed it as part of a strategic action, should this be considered a forced interaction rather than a violation by the Blue Robot? Major Violation or DQ?
  3. Should this situation be evaluated under the Game Manual principle that a Team may not force an opponent into a violation?
The concern is that if the ruling is based only on which Robot ultimately contacts or causes the opposing Stake to collapse, Teams may intentionally develop strategies that involve pushing an opposing Robot into their own Stake to force a penalty or Disqualification.
Clarification from the GDC would help Teams understand whether this type of strategy is legal and how Head Referees should consistently evaluate these interactions.<GG16>
We believe our answer to Q&A 3194 addresses your question. If it does not, please feel free to rephrase and re-submit.
3219: Clarification on Indirect Goal Interactions, Dislodged Pins, and Forced Violations (<SG9>, <SG10>, <GG16>)
29-Aug-2026
GG16 SG9 SG10
Dear Game Design Committee,
We have a few questions on interactions with Goals.
<SG9>: “Robots may not directly or indirectly interact with opposing Alliance-colored Goals.”
<SG10>: “Placed Scoring Objects cannot be removed from neutral Goals.”
<GG16>: A Robot may not force an opposing Robot into a violation.
Our first question is, if a Robot contacts a neutral Goal itself, but does not directly contact any of the Placed Pins, and the impact or movement of the Goal causes a Placed Pin to fall, would this violate <SG10>? Or does the Robot need to directly contact the Placed Pin for <SG10> to apply?
Our second question is, if a Red Robot and a Blue Robot are both competing for the same Toggle, and the Red Robot pushes the Blue Robot toward a neutral Goal, causing a Placed Pin to fall, would the Red Robot violate <SG10>? Would Red still be considered in violation if Red was only trying to compete for the Toggle and did not intentionally try to remove the Pin? Would Red also violate <GG16> for forcing Blue into an interaction that would otherwise be a violation?
Our last question is, if the same situation happens with a Blue Alliance-colored Goal, where Red and Blue are competing for the same Toggle and Red pushes Blue into the Blue Alliance Goal, would the Red Robot violate <SG9>? Would this count as indirect interaction with an opposing Alliance-colored Goal even though Red was only trying to compete for the Toggle? Would Red also violate <GG16> for forcing Blue into the Goal interaction?
If any of the situations described above are determined to be violations, would the consequence be different depending on whether the violation occurs during a Qualification Match or a Final Match? Specifically, would the violation be classified differently as a minor violation or a major violation in those two match types?
Thank you for taking the time, 68678C
If a Robot contacts a neutral Goal itself, but does not directly contact any of the Placed Pins, and the impact or movement of the Goal causes a Placed Pin to fall, would this violate SG10?
Yes, this would result in an SG10 Violation, with or without direct contact with the Placed Scoring Objects.
If a Red Robot and a Blue Robot are both competing for the same Toggle, and the Red Robot pushes the Blue Robot toward a neutral Goal, causing a Placed Pin to fall, would the Red Robot violate SG10? Would Red still be considered in violation if Red was only trying to compete for the Toggle and did not intentionally try to remove the Pin? Would Red also violate GG16 for forcing Blue into an interaction that would otherwise be a violation?
The red Robot would receive both an SG10 and a GG16 Violation for causing the blue Robot to remove Placed Scoring Objects from the neutral Goal, regardless of intent.
If the same situation happens with a Blue Alliance-colored Goal, where Red and Blue are competing for the same Toggle and Red pushes Blue into the Blue Alliance Goal, would the Red Robot violate SG9? Would this count as indirect interaction with an opposing Alliance-colored Goal even though Red was only trying to compete for the Toggle? Would Red also violate GG16 for forcing Blue into the Goal interaction?
The red Robot would receive an SG9 Violation for indirect interaction with an opposing Alliance-colored Goal. (Most likely only a Minor Violation, unless the interaction results in the removal of Placed Scoring Objects, which would escalate it to a Major.) The red Robot would not receive a GG16 Violation since the blue Robot was not forced into any Violation. (The blue Robot is allowed to interact with their own Alliance-colored Goal.)
Would the consequence be different depending on whether the violation occurs during a Qualification Match or an Elimination Match? Specifically, would the violation be classified differently as a minor violation or a major violation in those two match types?
No. Rule Violations are handled in the same way across both Qualification and Elimination Matches, unless a particular rule's Violation notes state otherwise.
3285: SG11 Holding a Pin down in the Loader
18-Oct-2026
GG18 SG11
<SG11>
Q&A 3235 clarified that the following image is entirely legal [Example Image]
If a team member is actively pushing down on the loaders handle to hold the following Pin and Cup in place so a robot can come and picks up the pin and cup, is that considered "Excessive, unnecessary, or unsafe actions" or <GG18> Use Scoring Objects to play the game? <GG18> Or is this entirely legal a strategy in holding things in place?
There are no rules prohibiting this interaction. It would be legal for a Drive Team Member to push down on a Loader handle, such that the Loader is applying force to hold a Pin and Cup in place.
3205: Clarification of <GG4> and <SG11>: Hand in Loader to Place a Match Load
15-Aug-2026
GG4 SG11
We are seeking clarification regarding <GG4> and <SG11> when using the Match Loader. <GG4> <SG11>
The Match Loader is in its fully lowered position. A Drive Team Member places a single Pin into the Match Loader and briefly puts their hand inside the Loader in order to properly position the Pin.
The sequence is:
The Match Loader is fully lowered. The Drive Team Member places a single Pin into the Loader and briefly reaches their hand inside the Loader to position the Pin properly. The Drive Team Member completely removes their hand from the Loader. After the hand has been fully removed is the Match Loader raised.
At no point is the Match Loader raised while the Drive Team Member's hand is inside it.
Would briefly placing a hand inside the fully lowered Match Loader for the purpose of properly positioning a Pin be considered a violation of <GG4> or <SG11>?
More specifically, does the hand entering the Loader in this manner count as entering the 3-dimensional volume of the Field under <GG4>, or is this action permitted as part of Match Loading under <SG11>?
Thank you for your clarification.
<GG4> calls out introducing Match Loads per <SG11> as an exception to the "hands out of the Field" rule. A Drive Team Member is allowed to reach their hand into the field to place Match Loads down inside the Loader.
3255: Match loading clarification of Q&A 3205, SG11, GG4, and S1
28-Sep-2026
GG4 S1 SG11
GG4 states: a. Drive Team Members are allowed to reach into the Field during the Match while introducing Match Loads as described in rule <SG11>. Rule <S1> applies.
Q&A 3205 clarified that SG11 provides an exception to GG4 and allows teams to reach into the field to place a match “down inside the Loader”, to clarify that reaching into the Loader itself is legal.
The question is, how far can a loader reach into and through the Loader and still be “inside the Loader”?
Example photos are attached to show degrees of reach in match loading.
The first photo appears to be clearly “down inside the Loader”, and the fourth photo appears clearly not okay because the match load is outside the load zone. However, photos 2 and 3 show a match load where the hand leaves through the bottom of the loader and turns to reach outside of the Loader to place the match load. This seems inconsistent with GG4, keeping hands out of the field, and S1, be safe.
Appreciate any clarification on whether reaching out through the bottom of the Loader, as shown in photos 2 and 3, is still considered legally "inside the loader".
SG11 photos.pdf
In the October 8 game manual update, <SG11> will be revised to include new guidance on this issue. When introducing Match Loads to the Field through Loaders, Drive Team Members should never extend any part of their body beyond the bottom edge of the Loader plastic.
Per this new guidance, all four of your example photos represent an unsafe and illegal Loading method since the Drive Team Member's hand extends beyond the bottom edge of the Loader plastic.
3137: Match Replays for Single Robot Disconnect
14-May-2026
GG5
Point a-v of <GG5> states that a valid reason a match replay is (emphasis mine):
Field control disconnecting or Disabling multiple Robots. Note, this is sometimes confused with a Robot whose motors have overheated, or bent pins on a controller’s competition port causing intermittent drop-outs. In general, any true Field fault will impact both Alliances simultaneously, not one Robot at a time.
The red box below the rule states:
Note: Communication or control issues affecting a single Robot are not considered eligible grounds for a replay.
Suppose that a single Robot experiences a field disconnect during a Match. That Robot is the only Robot affected by a disconnect during the Match. After the Match, the Head Referee examines the Smart Field Controller and determines that the disconnect was caused by bent pins in the port of the Smart Field Controller (in other words, the disconnect was caused by an issue beyond the control of the Team). The Head Referee is sure that no other issues with the smart cable, Controller of the affected Team, or their Robot, could have caused the disconnect. Is rule GG5 stating that the Match should NOT be replayed?
This would be more akin to a Field hardware failure than a communications or networking issue between the Robot and the Field affecting a single Robot.
This may be considered grounds for a replay at the discretion of the Event Partner and Head Referee.
3233: Clarification of [SG10] Match Affecting Calculation When Both Alliances Remove Pins From Neutral Goals in the Same Match
13-Sep-2026
SG10 GG6
During a Hypothetical Head-to-Head Elimination match, the following occurs:
Blue 1 removes one Placed yellow Pin from the center neutral Goal in a single interaction. Blue 2 has no relevant violations. At a different point in the match, Red 1 removes three Placed yellow Pins from a different neutral Goal in a single interaction. Red 2 has no relevant violations.
Assume that for this question, neither interaction is considered intentional, strategic, egregious, or a repeated Minor Violation.
The final scored result of the Match, before considering rule violations, is:
  • Red Alliance 42
  • Blue Alliance: 50
Rule [SG10] states that Placed Scoring Objects may not be removed from neutral Goals. Its Violation Notes state that, for Match Affecting calculations, an interaction removing 1–3 Pins is evaluated at 10 points per Pin, while an interaction removing 4+ Pins is evaluated at a combined value of 50 points. It further states that if subtracting this value from the offending Alliance’s final score would change the outcome of the Match, the Violation should be considered Match Affecting.
Applying this calculation separately:
  1. Blue 1 removed 1 Pin, so Blue’s calculation would be 50 - 10 = 40. Since 40 is less than Red’s 42, Blue’s violation would appear to be Match Affecting.
  2. Red 1 removed 3 Pins, so Red’s calculation would be 42 - 30 = 12. Since Red already lost the Match, Red’s violation would appear not to be Match Affecting.
Appendix C also states that a Violation cannot be Match Affecting if the offending Team did not win the Match, and that Match Affecting Violations are normally Major Violations.
Based on this, we would like clarification on the following:
This interpretation appears to create a situation where Blue could receive a Disqualification specifically because Blue won the Match.
Particularly, if Blue had instead finished with 41 points and lost the Match 42–41, Blue’s same one-Pin removal would appear not to be Match Affecting. At the same time, Red would then be the winning Alliance, and Red’s three-Pin removal would appear Match Affecting under the 30-point calculation, since 42 - 30 = 12, which is less than Blue’s 41, disqualifying them. Is it therefore an intended consequence of [SG10] that, in this scenario, an Alliance could receive a more favorable Match result by finishing with a lower score and losing on the field rather than scoring additional points, winning on the field, and receiving a Disqualification?
In this double-violation instance, could both Alliances receive Disqualifications and the Elimination Match (e.g., QF 2-1) be played again (e.g., as QF 2-2) to determine the Alliance that moves on in the bracket?
When both Alliances violate [SG10] in the same match, is there any circumstance in which the violations should offset one another? Specifically, should the value of Blue 1’s 10-point [SG10] violation be subtracted from the value of Red 1’s 30-point [SG10] violation, resulting in a net 20-point violation value attributed to Red for the purpose of determining whether Red’s violation was Match Affecting? (In this case, this would result in Blue winning the Match, because subtracting 20 points from Red’s 42-point score for the match-affecting determination would not change the original Blue victory.)
Or, is the correct application of [SG10] in this scenario to evaluate each Alliance’s violation independently against the original 42–50 final score, resulting in Blue receiving a Major Violation / Disqualification while Red’s violation remains Minor?
We are primarily looking for clarification on how [SG10] and the definition of Match Affecting should be applied when both Alliances commit separate [SG10] violations in the same Match, especially when the Alliance with the smaller violation wins with the original, unadjusted score.
Thank you for your time.
This process for handling Match Affecting calculations now works differently than in the past, and we acknowledge that the current <SG10> Violation notes do not make this process clear. We will attempt to correct that in the next game manual update.
The calculations for SG10 Violations should first be taken into account for both Alliances at the same time, prior to determining whether any Violation affected the outcome of the Match in favor of one Alliance or the other.
SCENARIO #1- Using your Elimination Match scenario, here's how to handle the Match Affecting calculations for these SG10 Violations:
  • Red Alliance: 42 (final score) - 30 (value of removing 3 Pins) = 12 points (simulated final score)
  • Blue Alliance: 50 (final score) - 10 (value of removing 1 Pin) = 40 points (simulated final score)
When comparing both the final scores and the simulated final scores, we can see that the blue Alliance would win the Match both before and after taking these calculations into account. Therefore, these Violations committed by the red and blue Alliances are not Match Affecting, and would instead be considered Minor Violations for both Alliances. Remember, these calculated values are not actually deducted from official Alliance scores, so the final score of the Match remains 50 (blue) to 42 (red).
SCENARIO #2- Let's consider a different Elimination Match scenario, where the Violations affect the outcome of the Match in favor of one Alliance (red removes 2 Pins in a single interaction, and blue removes 4 Pins in a single interaction):
  • Red Alliance: 75 (final score) - 20 (value of removing 2 Pins) = 55 points (simulated final score)
  • Blue Alliance: 90 (final score) - 50 (value of removing 4 Pins) = 40 points (simulated final score)
The blue Alliance would win the Match before taking these calculations into account (shown by the final scores), but the red Alliance would win the Match after taking these calculations into account (shown by the simulated final scores). Therefore, the blue Alliance's more severe SG10 Violation was large enough to affect the outcome of the Match in their favor, which would result in a Match Affecting Violation (DQ) for the blue Alliance. The red Alliance's SG10 Violation would only be considered a Minor Violation in this case.
SCENARIO #3- Consider an Elimination Match scenario where taking into account all Match Affecting calculations for both Alliances results in a virtual tie (red removes 3 Pins in a single interaction, and blue removes 1 Pin in a single interaction):
  • Red Alliance: 80 (final score) - 30 (value of removing 3 Pins) = 50 points (simulated final score)
  • Blue Alliance: 60 (final score) - 10 (value of removing 1 Pin) = 50 points (simulated final score)
The red Alliance would win the Match before taking these calculations into account (shown by the final scores), but the Alliances would tie the Match after taking these calculations into account (shown by the simulated final scores). In this special case, both Alliances would incur Match Affecting Violations, and both Alliances would be disqualified for the Match. (In Appendix C, the last bullet point listed under “Match Affecting“ will be revised in the next game manual update to remove any language that conflicts with this outcome. This answer takes precedence over any conflicting language within Appendix C regarding Match Affecting Violations.)
3135: Clarification on regarding temporary restriction of Toggle movement using a C-Channel
14-May-2026
GG9 SC4
Rule Quote: <GG9>
Robots may not intentionally grasp, grapple, hook, attach to or otherwise Entangled with any Field Elements. Strategies with mechanisms that react against multiple sides of a Field Element in an effort to latch or hook onto said Field Element are prohibited. The intent of this rule is to prevent Teams from unintentionally damaging the Field and/or from anchoring to or otherwise Entangling themselves with the Field. Whenever possible, Head Referees should alert Teams to potential Violations before they happen to prevent actual Violations. If a Robot takes immediate action to avoid or resolve the issue, and if the Head Referee determines that the issue had no effect on the Match, no Violation should be recorded.
<SC4>
SC4> A Toggle is considered set to a color when it meets all of the following criteria at the end of the Match: a. The Toggle must be fully seated, such that there is a face of the Toggle in contact and parallel with its mounts on the Field Perimeter at rest. (see Figure SC5-1) b. The Toggle is not in contact with a Robot from either Alliance.
Question: In the context of the current game, is it legal for a robot to position a piece of C-channel underneath the Toggle mechanism to prevent it from rotating?
The mechanism is not "clamped" or "grasped" in a way that prevents the robot from driving away (no permanent attachment), but the geometry of the C-channel effectively wedges the Toggle so it cannot be turned by an opponent. Does this "jamming" action constitute "attaching to a field element", or is it considered a legal defensive strategy provided the robot can move away freely?
Video I saw on youtube of this idea: https://www.youtube.com/shorts/Kyow3GVag-0
A Robot mechanism interacting with the Toggle as described is not inherently a GG9 violation.
Provided the Robot does not violate R18 and/or S1, this may be considered a legal gameplay interaction.
The Game Design Committee will continue to monitor Robot interactions with Toggles throughout the season, and this ruling may be subject to change if needed, based on observed gameplay.
3151: Is the heat dissipation for motor legal?
18-May-2026
R16
A.Is it legal to use active cooling devices for motor during the match? B.Is it legal to use active cooling devices for motor outside of the match? C.Is it legal to use passive cooling devices for motor? D.Is it legal to use thermal paste serves as an aid to heat dissipation for motor?
A) There is no rule explicitly preventing cooling devices during a match, however these devices must comply with all Robot Rules, including but not limited to R12, R16, R18, and R19.
B) There are no rules preventing cooling devices from being used before or after a Match.
C) There is no rule explicitly preventing cooling devices during a match, however these devices must comply with all Robot Rules, including but not limited to R12, R16, R18, and R19.
D) Thermal Paste is not legal for use in the VEX V5 Robotics Competition.
3157: R16 Vision Sensor Legality and legal parts list concerns
27-May-2026
R16
R16 states:
Any questions or concerns about legal parts should be directed to the official Q&A System on events.vex.com.
This is both a question and a concern. The VEX V5 vision sensor 276-4850 (sold by vex and used by teams for many years) is no longer listed in the competition legal parts list.
I have several questions/concerns:
  • Does this mean that the V5 vision sensor is no longer legal for use in V5RC? If so, why was this change made?
  • What other previously legal parts have been removed from the list since last season? It's hard to find previous versions of the list because its updated on a continual basis, and there are zero changelogs whatsoever. So, in order to determine what changed teams somehow must memorize the entire list and compare their memory to what is currently in the list.
  • Why are changes to the list not at least announced so that teams can review their parts in use? As it stands, many teams are likely to find out for the first time at a tournament inspection that their parts are no longer legal, because a silent edit to a google doc was made without their knowledge.
This was a mistake. The 276-4850 Vision Sensor has been added to the VEX V5 Robotics Competition Legal Parts List.
3140: Legality of Legacy (SMC) Pneumatics
15-May-2026
R19
<R19> Rule R 19 lists several Non-VEX components that are allowed. In previous years, both the manual and the knowledgebase listed the specific SMC legacy pneumatics components that were legal for competition use. This year there is no mention of the legacy pneumatics in the manual at all. They are not listed as allowed parts in R 19, but there is also no mention of them not being allowed in R 18, so there is a bit of confusion. Several other rules in the manual (GG3, R25, R26, etc) specifically mention VEX pneumatics parts. Am I correct to assume that this means that the legacy SMC pneumatics components are not legal to use this year and the only legal pneumatic components are the VEX branded ones?
Legal VEX Parts are listed in the Legal Parts list linked in the Game Manual.
Components not included in that list are not legal for competition use.
3206: Clarification of Rule <R19d>
17-Aug-2026
R19
Hey-
<R19> states that d. An unlimited amount of non-elastic rope/string, no thicker than 1/4” (6.35mm).
What defines non-elastic? Does string/rope that is inadvertently slightly elastic/stretchable to a negligible extent count as elastic, when the main purpose of the string/rope is not to take advantage of its elasticity?
We encourage Teams, referees, and inspectors to rely on <G3> when determining whether rope/string is elastic or non-elastic.
If pulling on a taut rope/string results in negligible or no discernible stretching, then the rope/string should be considered non-elastic. If pulling on it results in obvious stretching (like with a bungee cord, rubber band, etc.), then it should be considered elastic. The use case is irrelevant.
3261: Legality of springs
6-Oct-2026
R19
<R19>[<R19>] I have a question regarding springs. A team recently asked me if they could use a spring on their robot. For example if they used a spring on a claw to get it to automatically close without motor power would that be legal? thank you Kamin
Commercially available springs are not legal for use on VEX V5 Competition Robots. Springs are not included in the non-VEX components permitted by <R19> or <R22>, and per <R16>, components not included in the V5RC Legal Parts List are not legal for competition use. Springs that are included as part of an official VEX V5 product remain legal, subject to <R27> and <R28>.
3264: Fishing Line
7-Oct-2026
R19
d. Is non elastic fishing line legal as a rope/string?
Yes, as long as it is non-elastic and no thicker than 1/4" (6.35mm), per <R19d>.
3133: Legality of painted screw heads and anodized aluminum standoffs
14-May-2026
R23
<R23> reads:
Anodizing, painting, dyeing or changing the color of any legal VEX part is prohibited.
Our team has many RoboSource "Color Coded Star Drive Screws" where the screw heads have been painted by the vendor.
Related to this, we also have many RoboSource "Color-Coded Standoffs" which are anodized aluminum.
Technically, none of us painted or anodized the part ourselves - it came brand new painted and/or anodized from a well-known reputable vendor.
Are either or both of these two types of products legal?
Thank you!
R23a is intended to apply to parts made by VEX Robotics. It does not apply to commercially available hardware.
Provided the screws and standoffs meet the stated criteria in R22, these parts are legal for use in the VEX V5 Robotics Competition.
3136: Clarification on and regarding pneumatics with missing identification labels
14-May-2026
R23
<R23>
Decorations that cover or obscure identifying features of electronics and/or pneumatics parts are not legal. i. Teams will be asked to either replace the electronics and/or pneumatics part entirely, or remove the decoration if possible. ii. Identifying features include, but are not limited to, VEX logos, part numbers, and other distinctive colors or features of the part that allow an inspector to easily confirm it is a legal part.
Question: Over the course of normal use, the plastic protective wrapping/labeling on V5RC pneumatic reservoirs and cylinders can become frayed, damaged, or fall off entirely, removing the VEX logo and part number. If a pneumatic part is otherwise identical in form and function to an official VEX part but is missing its factory label/logo due to wear and tear, is it still considered legal for competition use and furthermore, what secondary identifying features should a team point to during inspection to "easily confirm" the part is legal if the primary logo is missing?
Normal wear and tear that damages factory-applied labels does not inherently make an otherwise legal pneumatic component immediately illegal.
Inspectors may use other identifiable characteristics of the part, such as its dimensions, construction, fittings, color, shape, or other distinctive features, to determine whether it is a legal VEX component. Comparing the part to a known-legal component with intact factory labels may help facilitate this process.
The easiest way to ensure inspection of these parts proceeds smoothly is to ensure that factory labels remain clearly visible to Robot inspectors whenever possible.
Teams should expect additional scrutiny if a part cannot be readily identified during inspection, and should understand that inspectors may deem a part illegal if they cannot reasonably verify that it is a legal VEX component.
3147: Inquiry on Broadness of R23 Application
17-May-2026
R23
Our team's questions are as follows, with two specific examples which we would like clarified.
(a) Rule <R23> states that “Decorations that cover or obscure identifying features of electronics and/or pneumatics parts are not legal.” Identifying features are defined following this, with "Identifying features include, but are not limited to, VEX logos, part numbers, and other distinctive colors or features of the part that allow an inspector to easily confirm it is a legal part." In some cases, modifications to VEX parts which remove material may remove the presence of VEX logos, listed as an identifying part. These modifications are not necessarily due to decorations, but they do remove the VEX logo, and may be for either functional or aesthetic reasons otherwise legal. Will such modifications be legal in general in the future?
Now, we would like to ask about specific applications of this rule.
(b) Teams have cut VEX gears for many seasons now in order to reduce drivetrain space and weight. Cutting or modifying these gears as has been standard for past seasons would potentially remove VEX logos, an identifying part. Will cutting of gears in ways that may remove the VEX logo be legal this season and in following seasons?
(c) Many teams have removed the vinyl wrapping on their air tanks and air cylinders. This does not affect the functionality of the air cylinder or air tank, and is usually made for aesthetic reasons or after damage to the vinyl wrapping. Removing the vinyl wrapping will remove VEX logos. Will air cylinders and air tanks with the vinyl wrapping removed be legal this season and in upcoming seasons? If not, how does VEX robotics plan to allow old pneumatics sets with these vinyl wrappings removed to be legal, if at all?
(d) Hypothetically, if a team was to remove the VEX logo from parts for little to no gain, like shaving off the VEX logo off new aluminum C-channels or sandblasting the surface of a VEX gear or sprocket, how would this be ruled?
(e) In the past, teams have been known to use rubber bands or zipties to connect the VEX V5 Smart Motor cap and body, in order to improve maintainability and serviceability in the middle of a competition. This is commonly referred to as allowing a motor to be "hotswapped". However, in some cases, these zipties or rubber bands can cover the VEX logo on these motors, which are electronic parts. Will such hotswapping setups be allowed in this season and onwards? If not, <R23> also states that the appropriate way to address this is to "remove the decoration if possible". Would this removal be only for inspection, or would it be for the duration of the competition? Broadly applied, since the intent of this rule is to aid in inspection, do restrictions on decorations potentially obscuring VEX identifying features apply only during inspection, or through the full duration of the competition?
(f) Finally, what are some general guidelines our team can apply to decide the legality of modifications which remove identifying features in the future? We ask this on an understanding that not every edge case can be covered here, but the manual is vague on these guidelines as well.
a. Please note that <R23> clause F applies to decorations that cover or obscure identifying features of electronics and/or pneumatic parts, and <R28> prohibits modifications to electronic or pneumatic components.
b. Gears are not considered electronic or pneumatic parts and are therefore not subject to <R23> clause F.
c. Teams should not intentionally remove or cover the labels/logos on their pneumatic cylinders or tanks. Regarding damaged or missing labels/logos, please see our response to Q&A 3136.
d. Gears, sprockets, and C-channels are not considered electronic or pneumatic parts and are therefore not subject to <R23> clause F.
e. Rubber bands and/or zip ties used to secure V5 Smart Motor Caps would be considered functional parts. <R23> clause F specifically restricts non-functional decorations.
If you have any remaining questions that you believe we have not adequately addressed with the answers above, please feel free to submit a follow-up question.
3148: Inquiry on the Application of R23 Part (a) on COTS and Previously Anodized Parts
17-May-2026
R23
Our question relates to the application of <R23>; specifically, <R23> part (a), stating that "Anodizing, painting, dyeing or changing the color of any legal VEX part is prohibited."
(a) The VEX manual clearly states that some commercial off-the-shelf parts are legal, as has been standard for past seasons. Some of these parts come in color; for example, some companies sell nuts which come in color, and many teams choose to use screws with colored heads to aid in identification of screw lengths. These COTS colored parts can be considered to be outside the category of "legal VEX part", as they are not manufactured by VEX. Will these parts be legal? Broadly applied, does legal VEX part apply only to parts sold and distributed by VEX Robotics, Inc.?
(b) i. Many teams in the past have used anodized metal parts like C-channels or dyed parts like gears. Before the 2026-27 season, these parts were already dyed or anodized. The language of <R23> states that the action of anodization/painting/dyeing/coloring is not legal, but it does not state that the use of previously anodized/painted/dyed/colored parts is illegal. This part of the rule was not present before the 2026-27 season. Does <R23> forbid the action of anodizing, painting, dyeing, or changing the color of any legal VEX part from the 2026-27 season onwards, or is it meant to be applied in retrospect, overriding previous game manuals, thereby banning all parts that have been anodized, painted, dyed, or color-changed, including ones teams already owned, and that were previously legal?
(b) ii. This is a follow-up to (b) i. IF all anodized/dyed/painted/colored parts are banned. Does VEX have a plan to compensate or alleviate the financial burden on organizations which have a large amount of these parts? <R23> (a) was added to the rulebook without warning, and many teams operated under the expectation that these previously unambiguously legal parts would be continually reusable for future seasons, as is the intent with purchasing these parts; they are an investment towards students' education for the season the parts are bought in and many seasons following. How does VEX intend these teams to deal with the sudden financial burden of needing new parts?
Please see the following statement from VEX Robotics and the VEX Robotics Game Design Committee regarding R23a, alongside the June 4 Game Manual update.
https://www.vexforum.com/t/a-message-from-vex-robotics-r23a-and-smc-pneumatics/146777
If you still have any questions regarding rules clarifications, feel free to submit a follow-up question. For questions, suggestions, or concerns that go beyond rules clarifications/interpretations, please direct them to [email protected].
3156: Legality of Brain-Controlled LEDs via Custom Non-VEX Wire and Solderless Crimp into a 3-Wire Port
27-May-2026
R23 R28
<R28> <R23>
We are seeking clarification on whether our specific LED implementation is legal under the current Override game manual.
Our Setup:
A custom-made, non-VEX-branded 3-conductor wire with the appropriate 3-wire port connector on one end, plugged directly into a 3-wire port on the V5 Brain. The other end connects to an LED via a solderless crimp - no soldering, welding, gluing, or brazing is involved at any point. The LED has no independent power source and no independent microcontroller. It is powered and controlled entirely by the V5 Brain. The intended use is as a non-functional visual decoration to provide robot state feedback to our drive team. Question 1 - Does <R28> Apply to Our Custom Wire?
<R28> restricts modifications to electronic or pneumatic components of the VEX platform, specifically including "cables" and "any other electrical component of the VEX platform." Our 3-conductor wire is not a VEX component, it was fabricated from scratch and is not a modified or repaired VEX cable. We believe <R28> therefore does not govern this wire at all, as it only addresses modifications to existing VEX-platform components.
Is this interpretation correct, that <R28> does not apply to a custom-built wire that was never a VEX component to begin with?
Question 2 - Is There Any Rule Restricting What May Be Plugged Into a 3-Wire Port?
We are not aware of any rule in the current game manual that requires the wire or device plugged into a V5 Brain 3-wire port to be a VEX-branded component. <R20> governs custom V5 Smart Cables and restricts smart port usage to legal electronic devices, but we cannot identify equivalent language restricting 3-wire port connections to VEX-branded components only. The 3-wire port is a standard physical interface that VEX designed for external connections.
Is there any rule that prohibits plugging a custom (non-VEX) wire into a V5 Brain 3-wire port?
Question 3 - Legality as a Non-Functional Decoration Under <R23>
Assuming Questions 1 and 2 are resolved in our favor, we believe our LED qualifies as a legal non-functional decoration under <R23>. Specifically:
It does not affect robot performance or the outcome of a match. It serves no structural function. It does not mimic field elements or interfere with opponent sensors. It is powered solely by the V5 Brain battery, no additional power source. It is controlled by the V5 Brain, no additional microcontroller. In previous years, decorative LEDs controlled by the V5 Brain and used to provide visual feedback to drive team members have been permitted to an extent. The current <R23> continues to allow non-functional decorations, and we believe this use case falls within that permission.
Is a Brain-controlled LED, connected via a custom non-VEX wire plugged into a 3-wire port, legal as a non-functional decoration under <R23>, including for the purpose of providing visual robot-state feedback to drive team members?
Is a Brain-controlled LED, connected via a custom non-VEX wire plugged into a 3-wire port, legal as a non-functional decoration under R23, including for the purpose of providing visual robot-state feedback to drive team members?
LEDs connected directly to a V5 Brain 3-wire port via custom wiring are considered a legal, non-functional decoration, provided that the system otherwise complies with <R23> and all other applicable Robot rules. (<R28> does not apply to this custom wire.)
Per <R23>, LEDs that provide feedback to a Robot are considered functional. LEDs that only provide feedback to Drive Team Members (i.e., not a Robot) are considered non-functional for the purposes of this rule.
As described, your LED implementation would be considered a legal, non-functional decoration.
3162: cooling devices for decoration
10-Jun-2026
R23
In what tense, cooling devices count as decoration?
Devices used for active cooling on a robot are intended to improve robot performance, and would therefore not be considered non-functional decorations per <R23>.
3129: Legality of reinforced plastic - R24
14-May-2026
R24
Rule <R24> governing custom plastics states: Legal plastic types are polycarbonate (Lexan), acetal monopolymer (Delrin), acetal copolymer (Acetron GP), POM (acetal), ABS, PEEK, PET, HDPE, LDPE, nylon (all grades), polypropylene, PTFE, and FEP.
Certain manufacturing styles, such as SRPP (Self-Reinforced Polypropylene) or SR-PET, use a woven structure of a specific polymer embedded within a solid base of that exact same polymer to increase strength. These materials do not contain any glass, carbon, or other foreign additives. They are made physically and chemically of 100% pure polymer. If a material is made entirely of a single plastic explicitly listed in <R24>, but utilizes this internal self-reinforced woven structure, is it considered legal provided it meets all other rule requirements (such as being non-shattering, staying within the maximum 0.070" thickness, and adhering to the individual piece limits)?
Note: This answer was revised on July 2, 2026.
In the July 2 game manual update, <R24> clause F was updated to include non-homogeneous plastics, such as woven (e.g., SRPP) and/or fiber-reinforced sheets, as prohibited materials.
3146: 2mm thickness plastic legal?
16-May-2026
R24
Do 2mm thickness plastic legal?
2mm Plastic is not legal, per R24.
Plastic thickness is limited to 0.070" (1.78mm)
A metric conversion will be added in the June 4 game manual update.
3152: VEX Pressure Gauge must goes on the robot?
18-May-2026
R26
VEX Pressure Gauge on the e high pressure side count as part of the robot or it can arbitrary disassembly like a pump?
The VEX Pressure Gauge must be plumbed to the High Pressure side of the pneumatics system, and must remain on the robot during the match.
3272: What is required to fulfill the Vex Pressure Gauge requirement for <R26>
9-Oct-2026
R26
<R26> provides that the VEX Pressure Gauge is a required part if a Robot includes pneumatics, and it specifically provides the required part number 276-8748. That part number includes a red pressure gauge, regulator, and clip. The regulator has a gauge on it. <R26a> states that the gauge must be plumbed to the high pressure side of the system if the Team is using a regulator, which indicates that the regulator is not required even though it is included in the part number.
Are all the items in part number 276-8748 required on the robot or only the red pressure gauge that is included in the part number?
<R26> only requires Teams to use the V5 Air Pressure Gauge (if a Robot includes pneumatics). The other items included in the 276-8748 kit are not required.
3216: Questions On Plasma Cutters
22-Aug-2026
R27
A teammember is wondering how plasma cutters are considered when referencing rule R27.
R27 states that, “Metallurgical modifications that change fundamental material properties, such as heat treating or melting, are not permitted.” and if plasma cutting works by melting metal, “As the gas passes through the electric arc, the energy rapidly heats it, causing ionization. This transforms the gas into a high-velocity stream of plasma, which can reach temperatures exceeding 20,000 degrees Celsius (36,000°F). This jet is directed toward the metal workpiece, melting the material almost instantly at the point of contact.” while also causing a heat affected zone, “The heat affected zone (or simply HAZ) is something that occurs when metal is subject to high temperatures,” at the same time, then is plasma cutting illegal based on rule R27?<R27> Sources: VEX rules, content.vexrobotics.com/docs/2026-2027/override/files/override-v1.1.pdf Plasma melting and heat source, engineerfix.com/how-does-a-plasma-cutter-work-the-science-explained/ HAZ source, fractory.com/heat-affected-zone-causes-effects-reduction/
Plasma cutting is permitted under <R27> as a physical modification (cutting). <R27> clause B is mainly meant to prohibit intentional alteration of material properties (e.g., heat treating to increase hardness/strength), rather than incidental heating that occurs during a cutting process.
3182: Legality of Modified Motor Caps of 5.5W Smart Motors
6-Jul-2026
R28
<R28>
In <R28>, nothing is said about the legality of modifying motor caps of 5.5W Smart Motors. Should we assume that the 5.5W Smart Motor falls under V5 Smart Motors, or is it separate and illegal to modify?
The V5 Smart Motor Cap mentioned multiple times in <R28> is specific to the 11W motor, but the rule will be revised in the August 6 game manual update to extend the 11W motor's allowed modifications to equivalent parts of the 5.5W motor, including similar treatment of its motor cap as "not part of the motor".
3257: R28 Distance Sensor Clarification
1-Oct-2026
R28
<R28>
Is it legal to cut off or remove somehow the plastic side mounts of a distance sensor? R28 says no modifications to electronics, but this modification would not affect the functionality of this electronic.
<R28> will be revised in the December 3 game manual update to allow Teams to cut/modify the plastic mounting flanges for sensors that have them, such as the Distance Sensor, Optical Sensor, Bumper Switch, etc. For example, a Team could use only one of the Distance Sensor's mounting flanges, while cutting off the other flange to reduce the sensor's footprint and fit it into a smaller space on the Robot.
This change is effective immediately.
3279: Clarification regarding sensor mounts (R28)
16-Oct-2026
R28
<R28>
<VUR12g> explicitly permits the rotation of VEX optical and vision sensors about their mounting base. It is understandable that this does not apply to V5 MS/HS rules. It is legal to rotate the blocks of the V5 Optical Sensor and V5 Distance Sensor relative to their bases, and to manufacture custom back plates for these sensors
However, QnA 3257 (3257: R28 Distance Sensor Clarification) suggests that, being able to modify the mounting bases, that the flanges are not considered to be "part of the sensor", in the same way that motor caps are not considered to be "part of the motor". As such, is the ability to rotate the sensors relative to their mounting base also legal in V5? If so, would it also be legal to use these sensors without the mounting base or manufacture custom back plates (such as screwed directly into a custom polycarbonate sheet) if they are not considered "part of the sensor"?
In addition to the changes mentioned in Q&A 3257, the revision to <R28> in the December 3 game manual update will also allow a sensor to be unscrewed, rotated relative to its mounting plate, and screwed back in. Teams will still be prohibited from using these sensors without the mounting plate and from manufacturing custom mounting plates.
3265: License Plate Mounting Clarification
7-Oct-2026
R4
<R4><R4> Are we able to attach license plates like this and be in compliance with R4? They use 2 standoffs to slide the license plates over. They use a 2nd blank license plate (so use 4 of each color) to create a single license plate. It isn't being used for anything other than team number display and the 2nd plate is blank.
What if they use metal instead of a second plate - would they way they attach it to the robot (slipping over 2 standoffs) be considered secure?
[Example Image]
[Example Image]
[Example Image]
<R4b> requires license plates to be "securely attached to the Robot." The mounting method shown in your photos fails to meet that requirement. The red-border box under <R4> provides the following guidance for securely mounting your license plates:
When a license plate is mounted to the Robot, only human influence should be able to remove the plate. The mounting should be secure enough to withstand any and all interactions between the Robot and other things on the Field. Using rubber bands or other flexible mounting methods to mount license plates should not be considered secure, and should not pass inspection. Using screws and nuts/standoffs to mount plates is the best way to meet the requirements for securely mounted license plates.
Additionally, doubling up on license plates as shown in your photos would be a violation of <R4e>, which prohibits the use of additional license plates beyond the two required by <R4a>. Using metal in place of the second license plates on each side would avoid violating <R4e>, but merely sliding this over standoffs is still going to violate <R4b> for not being securely attached to the Robot.
3266: Fixed Location definition
8-Oct-2026
R4
<R4>
Referencing specifically the definition of "fixed location" in part a of R4. Does this mean that license plates must be attached to a part that doesn't move, or does it mean that it doesn't move from the part that it is attached to?
Example of each would be:
  1. License plates are attached to the drive train or a support beam and consistently stay at relatively the same height throughout the entirety of the match
  2. License plates are attached to a claw arm and remain fixed to the claw arm, but move up and down throughout the match as the arm moves up and down
Are both of these two examples legal?
This is clarified in <R4.a.i>:
i. License plates should be mounted in locations that remain stationary on the Robot during a Match (e.g., not on a rotating intake or flipping manipulator). The function of license plates is to identify Robots for referees, spectators, and other Teams. Identification is harder when a license plate on a Robot moves during a Match.
Your first example would be legal, since the license plates would be mounted in a fixed/stationary position on the Robot. Your second example would not be legal, since the license plates would be mounted on a mechanism that is moving/lifting/rotating (i.e., a non-stationary mounting location).
3242: <SG12> Question About Scoring in Midfield during Skills
18-Sep-2026
RSC1 SG12
According to <SG12>, robots cannot score in the midfield in the last 20 seconds. In <RSC1>, it states "All rules from previous sections apply to Robot Skills Matches, unless otherwise specified in this section." Does this also mean that you cannot score in the midfield during the last 20 seconds of a skills run?
<SG12> states that "Robots may not Place Scoring Objects on the Midfield Goal during the Endgame period."
The Endgame period is defined as follows:
Endgame - A time period consisting of the last 10 seconds of a Head-to-Head Match, in which Robots attempt to end the Match in the Midfield. See rule <SG12>.
There is no Endgame period in a Robot Skills Match, so <SG12> does not apply to Robot Skills Matches.
3199: Skills Scoring question
7-Aug-2026
RSC3
<RSC3>
RSC3, bullet iv indicates a Pin in contact with a Robot at the end of a Match does not score points.
What if a Pin is inside a Cup and the Robot is contacting only said Cup? Is it scored or not?
In the September 3 game manual update, RSC3.a.iv will be removed. Robot contact with Pins and/or Cups will have no affect on whether or not a Pin is considered Scored. This change is effective immediately.
3236: Robot Skills Setup
16-Sep-2026
RSC4
<RSC4>
In regards to Field Set up, I am not seeing any language regarding where the Red Alliance quadrants should be for the driver station. Specifically with the requirement of the GPS strips, where should the the driver station be in respect to the 0 degree section of the GPS strips?
The 0-degree mark and red Alliance Station are in the same locations for all Match types.
Specific field layouts, which show the locations of the Alliance Stations relative to the Field, can be viewed in their respective sections of the game manual. The location of the 0-degree mark can be found in various Appendix A drawings or in the build instructions for the Field.
In Figure RSC4-1, which shows an overhead view of a V5RC Override Robot Skills Match layout, the 0-degree mark would be located at the center of the top wall.
3294: April Tag layout for the Robot Skills Field goals
21-Oct-2026
RSC4
<RSC4>I have not located the positioning requirements for April tags on the 5 goals on the Robot Skills Field setup. Are they the same as corresponding goals on a competition field, or is there a different layout for the Robot Skills fields?
The AprilTag layout is the same for both Head-to-Head Matches and Skills Matches.
3278: Clarification on Robot Starting Position and Field Perimeter Plane relative to Toggles
15-Oct-2026
S4
<S4><S4>Could the GDC please clarify the legality of a robot's starting configuration regarding the field perimeter plane and the Toggles under Rules <SG1>, <SG5>, and <S4>? Because the Toggles are mounted directly on top of the 2-inch wide field perimeter wall, a mechanism designed to flip them may need to sit directly above the Toggle before the match begins.
  1. Is a robot permitted to start the match with a mechanism positioned directly over or on top of a Toggle (within the 2-inch thickness of the perimeter wall), provided there is no physical contact with the Toggle or the perimeter wall?
  2. Does a mechanism positioned vertically over the Toggle at the start of the match violate the 3D vertical plane boundary of the field perimeter under Rule <S4> ("Stay inside the Field")?
  1. Is a robot permitted to start the match with a mechanism positioned directly over or on top of a Toggle... provided there is no physical contact with the Toggle or the perimeter wall?
There are no rules prohibiting a Robot from extending over the Field Perimeter or over a Toggle prior to the start of the Match. <SG1.c> prohibits a Robot from contacting any Toggles prior to the start, but contact with the Field Perimeter is actually required by <SG1.f> in order to start the Match.
  1. Does a mechanism positioned vertically over the Toggle at the start of the match violate the 3D vertical plane boundary of the field perimeter under rule <S4>?
It's legal for a Robot mechanism to be positioned over (but not in contact with) the Toggle prior to the start of the Match. <S4> is not meant to penalize mechanisms that cross the Field Perimeter as a part of normal, expected gameplay. The rule never defines a vertical plane boundary that a Robot is prohibited from crossing. Rather, it applies to Robots that go completely outside the Field.
3244: Stacking multiple match affecting penalties
21-Sep-2026
SC1 SG10
In the 2.0 manual, Appendix C - Rule Violations: "Match Affecting - A Violation which changes the winning and losing Alliance in the Match. Multiple Violations within a Match can cumulatively become Match Affecting."
This question presents scenarios where multiple match affecting violations occur in a single match and seeks clarity how to apply them.
Scenario 1 One robot, same goal: Blue1 descores two pins from a neutral goal, then later in the match Blue1 descores another pin from the same neutral goal.
Scenario 2 One robot, different goals: Blue1 descores two pins from a neutral goal, then later in the match Blue1 descores another pin from a different neutral goal.
Scenario 3 Two robots, same alliance: Blue1 descores two pins from a neutral goal, then later in the match Blue2 descores another pin from a different neutral goal.
In all of these scenarios, the match ends with the score of Blue 85, Red 60. How should these match affecting violations be cumulatively applied and does the guidance change if the match is in qualifications or eliminations?
Per <SG10> violation note #1, the value of removed Pins is determined for each independent interaction/violation. When multiple violations occur, the point values attributed to each violation may then stack.
For example, if Blue 1 removes one Pin from a neutral Goal, that interaction is valued at 10 pts. If Blue 1 later removes 3 additional Pins from a neutral Goal, that interaction is valued at 30 points. The cumulative value of these potentially match affecting violations would be 40 points. (Note: This is not evaluated as a single interaction resulting in the removal of 4+ Pins, which would be valued at 50 points. These were two separate interactions, and the points from each interaction stack. The Pin counts do not stack.)
In Elimination Matches, violations are tracked and shared for the Alliance, rather than each individual Robot. For example, if Blue 1 removed one Pin from a neutral Goal, that SG10 violation would be valued at 10 points. If Blue 2 removed 2 Pins from a neutral Goal, that SG10 violation would be valued at 20 points. These separate SG10 violations stack and are cumulatively valued at 30 points for the blue Alliance in this Elimination Match. If the blue Alliance were to win this Elimination Match by 30 points or less, the 30-point advantage gained via SG10 violations would be considered Match Affecting (Major Violation) in favor of the blue Alliance, and the blue Alliance would be disqualified for this Match.
In Qualification Matches, violations are tracked for each individual Robot, rather than shared across both Robots on an Alliance. Multiple violations committed by the same Robot will stack and be cumulatively applied for only that Robot. Any Violations committed by the other Robot on the Alliance, along with any Match Affecting calculations, are handled independently for each Robot. If Red 1 removed one Pin from a neutral Goal, that SG10 violation would be valued at 10 points. If Red 2 removed one Pin from a neutral Goal in one interaction (10 points) and removed 2 Pins from a neutral Goal in another interaction (20 points), Red 2's SG10 violations would be cumulatively valued at 30 points. Now, here are some different scenarios to consider how each Robot might be affected for this Qualification Match:
  • If the red Alliance were to win this Qualification Match by 10 points, both Red 1's SG10 violation (worth 10 points) and Red 2's SG10 violations (cumulatively worth 30 points) would independently be considered Match Affecting in favor of the red Alliance, and both red Alliance Robots would receive Major Violations and disqualifications for this Match.
  • If the red Alliance were to win this Qualification Match by 15 points, Red 1's SG10 violation (worth 10 points) would not be considered Match Affecting, and would result only in a Minor Violation. Red 2's SG10 violations (cumulatively worth 30 points) would be considered Match Affecting in favor of the red Alliance, and the Red 2 Robot would receive a Major Violation and disqualification for this Match.
  • If the red Alliance were to win this Qualification Match by 40 points, neither Red 1's SG10 violation (worth 10 points) nor Red 2's SG10 violations (cumulatively worth 30 points) would independently be considered Match Affecting, so both red Alliance Robots would only receive Minor Violations for this Match.
3153: Clarification on Classification of Stacked Game Elements and Removal of Elements
22-May-2026
SC2 SG9 SG10
In the rulebook, <SG10> states that "Placed Scoring Objects cannot be removed from neutral Goals.". <SC2> clearly identifies an example of a position a pin may take on a stack which is not Placed, shown in Figure SC2-2 (pin placed horizontally on a cup without either half of the pin being entirely contained within the concave portion of the cup).
We wanted to ask about the legality of the following:
(a) Removing a Pin that is not Placed, such as a Pin positioned similarly to the one shown in Figure SC2-2.
(b) Removing a Cup which is similarly balanced horizontally on top of other game elements without being placed.
(c) Removing a Cup which is balanced on top of another Cup without a pin in between (or, similarly, a Pin balanced on a Pin with no Cups in between).
(d) Removing a Placed cup which is not affecting the score of the game (ex. transparent part facing downwards, with no pins above, thereby not adding or subtracting points from the game.
(e) If it would be a major violation to accidentally knock over protected scoring elements in an effort to reopen an alliance or neutral goal for scoring by removing a game element that was positioned on the goal but not Scored/Placed.
(f) Rule <SG9> states that "Robots may not directly or indirectly interact with the opposing Alliance-colored Goals", and clarifies that this includes adding and removing scoring objects. Would stacking a horizontal game element as seen in Figure SC2-1, or any unplaced game elements as stated above count as interaction with these goals? By definition, this is not Placed, and it is not an action of descoring, but it forces the opposing alliance to take time to reopen their own alliance's goal for scoring.
(g) If it would be a violation of <SG6> for one of these game elements to fall onto a bot already possessing 1 pin and 1 cup in the action of removing it from the goal.
Thank you so much!
Respondido por committee
Note: Rules <SG2>, <SG9>, and <SG10> have since been updated in later versions of the game manual. We have revised and reformatted your question to reflect that update and to make it easier to address your individual questions.
To answer questions (a), (b), and (c), <SG10> only applies to Placed Scoring Objects, so removing a Pin or Cup that is not Placed from on top of a neutral Goal would not be a Violation of <SG10>.
(d) Removing a Placed Cup from a neutral Goal would be a Violation of <SG10>, regardless of whether or not the Placed Cup affects the score of the Match.
(e) It’s legal to remove Placed Scoring Objects from your own Alliance-colored Goals, whether accidentally or intentionally. However, a Robot action that results in the removal of Placed Scoring Objects from a neutral Goal would be a Violation of <SG10>. This will escalate to a Major Violation if it’s considered to be Match Affecting, if it’s deemed by the Head Referee to be intentional and/or egregious, or at the Head Referee's discretion after committing repeat Minor Violations. (See Violation notes in Appendix C for more details.)
(f) Making contact with Scoring Objects stacked on an opposing Alliance-colored Goal would be considered interacting with that Goal, regardless of whether those Scoring Objects are Placed or not, which would result in an <SG9> Violation.
(g) If the Scoring Object falls into the Possession of a Robot that is already in Possession of 1 Pin and 1 Cup, the Robot would technically be in Violation of <SG6> for exceeding the Possession limit and must immediately stop all actions other than attempting to remove the excess Scoring Objects. The Robot would not be able to continue participating in gameplay until the excess Objects are removed from its Possession.
3175: SC2 Partially Covered = Scored / Invisible?
25-Jun-2026
SC2
Thanks all for Automate session June 22, nothing like breaking the game on our first spin - several questions ...
#5 Da Rules - SC2 A Pin is considered Placed if it meets all of the following criteria: i. The Pin is partially or entirely nested with a Goal, or with a Cup that is partially or entirely nested with another Placed Pin. ii. Each Goal and/or each half of a Cup nested with that Pin contains a maximum of one Pin half. (See Figure SC2-2.) b. A Cup is considered Placed if it meets the following criteria: i. The Cup is partially or entirely nested with a Placed Pin.
<SC2>
Da Question - SC 2 Placed scoring criteria has “partially” seated as a requirement unless specifically split – does count as scored, does this mean that the paritially seated / gray cup that partially covers a colored pin is NOT scored while still being partially visible or?
<SC3> states:
"To count as Scored for the corresponding Alliance, the half of the Placed Pin must remain fully visible (i.e, cannot be partially or fully nested inside the opaque half of a Cup)."
A half of a Placed Pin that is partially nested inside the gray half of a Placed Cup is not considered fully visible, and will not be Scored.
3253: Match affecting clarification on "pins" for SG10 violations
24-Sep-2026
SC3 SG10
From v2.0 manual: <SG10> Violation Notes.
"For the purposes of Match Affecting calculations, the removal of Placed Scoring Objects from neutral Goals should be evaluated as follows: 2. 3. a. For an interaction resulting in the removal of 1, 2, or 3 Pins, each Pin removed as part of this interaction should be considered worth a value of 10 points. b. For an interaction resulting in the removal of 4+ Pins, the Pins removed as part of this interaction should be considered worth a combined value of 50 points.
This question is the definition of "pin" in the violation note.
<SC3><SC3> "Each Pin consists of two halves. Each visible half of a Placed Pin counts as a Scored Pin, according to the following: Each visible red half of a Placed Pin counts as a Scored red Pin, earning points for the red Alliance. Each visible blue half of a Placed Pin counts as a Scored blue Pin, earning points for the blue Alliance. Each visible yellow half of a Placed and Owned Pin counts as a Scored yellow Pin, earning points for the Alliance that Owns the Pin. (See <SC5><SC5>.) For a Pin half to be considered visible, the Pinhalf must not be partially or fully nested inside the opaque half of a Cup.”
Below (image 1) is 2 (physical pins) or 3 (pin halves)?
[Example Image]
(these are not my drawings, I borrowed them from a friend)
Below (image 2) is 2? (2 physical pins, 2 pin halves)
[Example Image]
Below (image 3) is 3 pins? (3 physical pins, 3 pin halves)
[Example Image]
(image 4) [Example Image]
Currently, a whole Pin (consisting of two halves) is referred to as a "Pin", and a visible half of a Placed Pin is referred to as a "Scored Pin". We definitely understand the confusion here, and we're hoping to resolve this confusion between Pins and Pin halves in the next game manual update.
In Q&A 3232, we mentioned that when Scoring Objects were removed from neutral Goals, we felt that tracking extra details, such as which parts of Pins were visible or not, was likely too much of a burden on Head Referees that could lead to excessive guesswork. As a result, Head Referees should only count the number of whole Pins removed from the Goal for each SG10 Violation, not the number of visible Pin halves.
For example, if an SG10 Violation involved the removal of two whole Placed Pins (consisting of 4 Pin halves), that would count as 2 Pins removed, meaning this SG10 Violation would be valued at 20 points.
3171: SC4 Don't touch my toggle ... where?
25-Jun-2026
SC4
#1 Da Rule <SC4> <SC4> A Toggle is considered set to a color when it meets all of the following criteria at the end of the Match: a. The Toggle must be fully seated, such that there is a face of the Toggle in contact and parallel with its mounts on the Field Perimeter at rest. (see Figure SC5-1) b. The Toggle is not in contact with a Robot from either Alliance.
Da Question - Is the black bracket included in the “touch” of a toggle that would cause us to ignore the color of the toggle for scoring
The Toggle consists of all parts included in the assembly that spins and moves up/down within the slots of the metal brackets, but does not include the metal brackets themselves.
3188: Robots in midfield at end of Autonomous Period
17-Jul-2026
SC5 SC7 SG7 SG8
<SC7><SC5><SG7>
How would the robots in the midfield at end of autonomous period be counted? Shown in the picture illustrated below with 2 Blue robots and 1 Red robot. One Blue robot was contacting the midfield goal and also pushed the other red robot that parked first. Another blue robot crossed the double autonomous line but entered the midfield.
Per SC5b. A yellow Pin Placed in the Midfield is Owned by the Alliance that ends the Match with a greater number of Robots in the Midfield. As this is not end of the match, yellow pin shall not be counted even with 2 parked Blue vs 1 parked Red.
Per SC7a, Points for ending the Autonomous Period in the Midfield are not included in the calculation of an Alliance’s score for the purposes of determining the Autonomous Bonus. Thus the Yellow pin shall not be counted as owned by Blue Alliance.
Per SG7, <SG7> Don’t cross the Autonomous Line, and don’t interfere with your opponents’ actions. Are all 3 robots violating?
Per SG8, <SG8> Engage with the Midfield and/or Autonomous Line during the Autonomous Period at your own risk. In this case, even if the Blue robot entered midfield and pushed the Red robot that has parked ealier time, Per SC8d, no penalty shall be given to Blue Alliance.
[Example Image]
Result 1: No violation, midfield is allowed and autonomous line cross is allowed. With 2 parked blue vs 1 parked Red, Blue allicance won auton and also owned the yellow pin.
Result 2: No violation, midfield is allowed and autonomous line cross is allowed. Yellow pin is not owned by either Alliance. However, with 2 parked blue vs 1 Red, Blue alliance won the auton bonus points.
Result 3: All 3 robots violate SG7, thus no Auton bonus will be awarded.
Result 4: IF the Red robot did not enter the midfield but only the 2 Blue robots, then Red Alliance will receive the 12 AP, given Blue Alliance violating SG7
Could you clarify the robots in midfield at end of Autonomous Period, not end of match?
Concerning your example scenario:
  • Per <SC5> clause B, a yellow Pin Placed in the Midfield is Owned by the Alliance that ends the Match with a greater number of Robots in the Midfield. Since this is not the end of the Match, neither Alliance owns the yellow Pin Placed in the Midfield Goal, regardless of how many Robots from each Alliance are within the Midfield at the end of the Autonomous Period.
  • Per <SC6>, Robots do not receive credit for being in the Midfield until the end of the Match. Therefore, being within the Midfield at the end of the Autonomous Period has no effect on Autonomous Period scoring calculations.
  • The actions of the red and blue Robots that made contact in the Midfield are legal. Per <SG8>, Robots engaging with the Midfield or Autonomous Line during the Autonomous Period accept the risk of interaction with other Robots that are also engaging with the Midfield or Autonomous Line. Contact between these two Robots in the Midfield will not be penalized.
  • The other blue Robot appears as if it would've crossed the Autonomous Line by contacting foam tiles on the red Alliance side, which results in an <SG7> violation for this blue Robot and the Autonomous Bonus being awarded to the red Alliance.
Note: <SC7>clause A will be revised in the August 6 game manual update to remove potentially misleading language. The purpose of <SC7> clause A is to clarify that scoring methods that rely on Robots being in the Midfield at the end of the Match (e.g., points awarded for Robots being in the Midfield and for Ownership/Scoring of yellow Pins in the Midfield) are not in effect until the end of the Match, and are therefore not included in Autonomous Period scoring calculations for V5RC matches.
Those scoring methods are only included in Autonomous Period scoring calculations for VEX U matches, due to <VUG5> rule modifications that make these scoring methods "active" at both the end of the Autonomous Period and the end of the Match.
3282: Midfield Control for AWP
16-Oct-2026
SC7 SC8
<SC8> includes "At least six (6) Pin Halves Scored for your Alliance. (Does not include Pin Halves Scored in Quadrants on the opposing side of the Autonomous Line.)"
If an alliance controls, or shares control of the midfield at the end of Autonomous, are any pins there counted as meeting the 6 pin requirement?
Note: the requirement for World Qualifying events is 7 pins.
<SC7>, part A clarifies that end-of-Match calculations are not included the Autonomous Period, and Autonomous Bonus calculations. However, the game manual is silent on AWP and end-of-Match calculations.
The Scoring methods that rely on Robots’ end-of-Match positioning in the Midfield (e.g., Robots ending in the Midfield and Ownership of yellow Pins in the Midfield) are not included in Autonomous Period scoring calculations because they are not evaluated at the end of the Autonomous Period (only at the end of the Match, per <SC5.b> and <SC6>). <SC7.a> is intended to clarify and call attention to that detail.
<SC5.b> states, "For Pins Placed in the Midfield Goal, the yellow Pin Halves are Owned by the Alliance that ends the Match with a greater number of Robots in the Midfield." Yellow Pin Halves in the Midfield cannot be considered Owned until the end of the Match, which means they cannot be considered Scored for the Autonomous Period and cannot count toward Autonomous Win Point criteria.
Red and blue Pin Halves do not carry that same stipulation. For Pins Placed in the Midfield Goal, any visible red or blue Pin Halves would be evaluated at the end of the Autonomous Period, counting toward both Autonomous Period scoring and Autonomous Win Point criteria.
3154: Clarification of AWP Criteria
23-May-2026
SC8
In rule <SC8>, the first two criteria for the Autonomous Win Point are listed as (emphasis mine):
  1. At least seven (7) Pins Placed for your Alliance (does not include Pins scored in Quadrants on the opposing side of the Autonomous Line)
  2. At least three (3) Goals each contain at least two (2) Pins scored for your Alliance (does not include Goals in Quadrants on the opposing side of the Autonomous Line)
<SC3>states:
Each Placed Pin can have one or two Scored halves.
If a Pin (not in a Quadrant on the opposing side of the Autonomous Line) meets the definition of Placed but not the definition of Scored, does it count as "Placed for your Alliance" when regarding criteria 1 of the Autonomous Win Point?
AWP criteria were revised in the June 4 Game Manual update, clarifying that Pins must be Scored, not just Placed, in order to meet these requirements.
3179: Clarification of AWP
30-Jun-2026
SC8
Hello, <SC3c>: "Each visible yellow half of a Placed and Owned Pin counts as a Scored yellow Pin, earning points for the Alliance that Owns the Pin." <SC8>: An Alliance earns the Autonomous Win Point if it has "7 Pins scored for your Alliance."
Our question is about the meaning of "Pins scored for your Alliance" in <SC8>.
Since <SC3c> explicitly states that an owned yellow Pin is scored for the Alliance that owns it, does it count toward the seven Pins required for the Autonomous Win Point?
For example:
Blue Alliance has 5 blue Pins and 2 yellow Pins that are owned by Blue because the corresponding Toggle is set to Blue. Does this count as 7 Pins scored for Blue, satisfying the <SC8> requirement?
Could the GDC clarify whether "7 Pins scored for your Alliance" in <SC8> includes owned yellow Pins, or if it refers only to Alliance-colored (blue/red) Pins?
"Pins Scored for your Alliance" includes both Scored Alliance-colored Pins and Scored yellow Pins that are owned by your Alliance, and they count toward AWP requirements as long as those Scored Pins are not in Quadrants on the opposing side of the Autonomous Line.
The blue Alliance has 5 Scored blue Pins and 2 Scored yellow Pins that are owned by blue because the corresponding Toggle is set to blue. Does this count as 7 Pins Scored for blue, satisfying the AWP requirement?
Yes, that's correct.
3180: Clarification on Quadrant Naming and Identification
3-Jul-2026
SG1
The Glossary defines a Quadrant as one of four designated triangular areas of the Field. Each Quadrant is described as red or blue based on the Alliance-colored Goal it includes.
However, the VEX Tournament Manager labels the four Quadrants as “Red Quadrant 1”, “Red Quadrant 2”, “Blue Quadrant 1”, and “Blue Quadrant 2”.
Could the GDC please clarify:
Which specific Quadrant corresponds to each label in the scoring app (e.g., is Red Quadrant 1 the one closest to the red Alliance Station, etc.)? Will these labels be used consistently across all official scoring systems and event materials?
This clarification would help Teams, referees, and scorekeepers ensure consistent communication during events.
To help maintain consistent scoring inputs in Tournament Manager, Figure Q-1 will be revised in the August 6 game manual update to label the four Quadrants as Red 1, Red 2, Blue 1, and Blue 2.
Red Quadrant 1 will be adjacent to the red Alliance Station, and Blue Quadrant 1 will be adjacent to the blue Alliance Station.
3194: Clarification for goal interactions
28-Jul-2026
SG9 SG10
<SG9>Dear Game Design Committee, We have a few questions on the interactions with goals. <SG9>: “Robots may not directly or indirectly interact with opposing Alliance-colored Goals.” <SG10>: “Placed Scoring Objects cannot be removed from neutral Goals.” The rulebook had no mention on interactions with Goals on the their own alliance.
Our first question is, is the removal of Scoring Objects on our own alliance allowed? For example: Blue alliance has stacked up on blue alliance goals and they topple their pins and cups over, would such actions violate the game rule?
Our second question is, if an interaction with neutral or opposing goal is forced, such as the blue alliance contacts an opposing goal due to a red alliance robot playing pushing the blue alliance, or toppling over pins scored in neutral goals due to an opponent robot pushing the robot towards the goals, would blue alliance violate rules <SG9> and <SG10>?
Our last question is, does toppling pins scored on your own alliance goals due to opponent contact cause our opponent to violate the rules? For example, blue alliance was scoring a pin on top of their goal, and a red alliance robot pushes the blue alliance robot toward their goal, causing them to topple over the scoring objects. Would red alliance violate the rules doing so? Quoting <SG9>: “Robots may not directly or indirectly interact with opposing Alliance-colored Goals.” Would this count as indirect interaction, therefore giving red alliance a penalty? Thank you for taking the time, 68678M
  1. There is no rule preventing the removal of Scoring Objects from your own Alliance-colored Goals. Red Robots can remove Scoring Objects from red Alliance Goals, and blue Robots can remove Scoring Objects from blue Alliance Goals.
  2. In an example scenario where a red Robot pushes a blue Robot into a red Alliance Goal, the red Robot has forced the blue Robot into a penalty. The same logic applies if red pushes blue into a neutral Goal, causing the blue Robot to knock Scoring Objects out of the neutral Goal. In either case, the red Robot's <GG16> Violation will override the blue Robot's <SG9>/<SG10> Violation for this interaction.
  • The blue Robot will not receive an <SG9>/<SG10>Violation since they were forced into it by an opposing Robot.
  • The red Robot will receive a <GG16> Violation for forcing an opposing Robot into a penalty. (For the scenario involving the neutral Goal, the red Robot would also receive an <SG10> Violation for indirect removal of Scoring Objects from the neutral Goal.)
  1. In an example scenario where a red Robot pushes a blue Robot into a blue Alliance Goal, causing the blue Robot to knock Scoring Objects out of the blue Alliance Goal, the red Robot has not forced the blue Robot into a penalty. However, the red Robot will receive an <SG9> Violation for indirect interaction with an opposing Alliance-colored Goal.
3195: SG10 & Violation Escalation: Clarification on removing multiple Scoring Objects in a single action
31-Jul-2026
SG10
Under <SG10>, Robots are not permitted to remove Scoring Objects from Neutral Mobile Goals. The rule notes that a Violation of this rule may lead to a penalty and could be Match Affecting.
At recent regional events, there has been a difference in interpretation regarding how SG10 violations should escalate to a Major Violation (Disqualification):
Interpretation A (Local Event Ruling): If a Robot removes two or more Scoring Objects in a single continuous action, the infraction automatically escalates to a Major Violation resulting in a Disqualification (DQ), regardless of whether the action directly altered the outcome of the Match.
Interpretation B (Manual Interpretation): A single action removing multiple Scoring Objects constitutes a Minor Violation unless it is determined to be Match Affecting or part of a pattern of repeated Violations after a warning, as per general rule guidelines.
Questions for the GDC:
  1. Does removing two or more Scoring Objects in a single action automatically constitute an automatic Major Violation (DQ) on its own?
  2. Is the escalation from a Minor Violation to a Major Violation under SG10 strictly governed by whether the action is Match Affecting (or repeated), or can a Head Referee escalate it to a Major Violation based solely on the quantity of Scoring Objects affected in a single event?
Thank you for your time and clarification!
No, removing some "X" number of Scoring Objects from a neutral Goal does not automatically result in a Major Violation on its own.
  1. Is the escalation from a Minor Violation to a Major Violation under SG10 strictly governed by whether the action is Match Affecting (or repeated), or can a Head Referee escalate it to a Major Violation based solely on the quantity of Scoring Objects affected in a single event?
As stated in the <SG10> Violation notes, an <SG10> Violation can escalate from a Minor Violation to a Major Violation under any of the following conditions:
  • The Violation was determined to be Match Affecting in favor of the offending Team's Alliance.
  • The Violation was determined by the Head Referee to be intentional, strategic, or egregious.
  • The Violation is one of multiple <SG10> Violations in a repeated pattern of infrigement by a Team over the course of a Match/event, in which case escalation is at the discretion of the Head Referee.
3224: Clarification for SG10 Intent
4-Sep-2026
SG10
<SG10> During a practice scrimmage, RED 1 (during the endgame) goes to push BLUE 1 out of the midfield. During the interaction, RED 1 causes BLUE 1 to impact the base of the midfield goal. Neither robot ever contacts any scoring objects, but the force of the impact causes a pin to become descored. As per SG10, it states "Pushing an opponent robot into Scoring Objects stacked on the goal [...]". The rule states being pushed into a scoring object, not the base of the goal. I assume this interaction would be ruled as a violation, but we wanted to get clarification on how this should be ruled.
This would be considered an indirect interaction resulting in the removal of Placed Scoring Objects from a neutral Goal, which would incur an <SG10> Violation. (The list of example interactions is not all-inclusive.)
The red Robot in your example would receive both an <SG10> and a <GG16> Violation for causing the blue Robot to remove Placed Scoring Objects from the neutral Goal.
3232: SG10 penalty assignment
13-Sep-2026
SG10
SG10 states that scored objects may not be removed from neutral goals and violation of this rule would result in match affecting calculations of 10, 20, 30, or 50 points (subtracted from the offending alliance's final score).
  1. RED robot is scoring yellow pins on a neutral goal and while placing the 6th pin, accidentally topples the stack of pins. RED had scored all of the yellow pins that were knocked off. Does RED receive the 50 point deduction when evaluating if it was match affecting?
  2. RED robot has scored 5 red pins on a neutral goal and while placing the 6th red-colored pin, accidentally topples the stack of pins. Does RED still receive the 50 point deduction when evaluating if it was match affecting, even though the pins removed from the neutral goal were red pins?
  3. RED robot has scored a mix of yellow and red pins on a neutral goal and while placing the 6th pin, accidentally topples the stack of pins. Let's say 3 yellow pins and 2 red pins were removed from the neutral goal. Does RED receive a 50 point deduction when evaluating if it was match affecting, based on the total number of pins that were removed from the neutral goal?
Remember, Head Referees only check to see if subtracting these values from the offending Alliance's score would change the outcome of the Match. These values are not actually subtracted from Alliance scores.
The red Robot caused the removal of Scoring Objects from the neutral Goal in all three scenarios, so red is the offending Alliance for all three scenarios. It does not matter which Alliance Placed the Scoring Objects in the neutral Goal or which Alliance they were Scored for.
We know that it's counterintuitive for a red Robot to be punished for removing red Pins from a neutral Goal, since doing so only hurts the red Alliance's score. However, it was decided that this color-agnostic approach to the Pins was needed to make calling <SG10> Violations more manageable for Head Referees. It's difficult enough to try to determine the number of Pins removed. We felt that trying to track additional details, such as which color Pins were visible in the stack, was too much to ask of Head Referees in these moments, and likely would've lead to excessive guesswork and more inconsistent punishments.
3249: <SG9>, <SG10>, and Descoring an Alliance's Own Alliance Goal
21-Sep-2026
SG9 SG10
This is a question that, although general in nature, is related to a recent referee decision that I am unable to find any rule justifying.
Scenario:
A blue robot decides it is strategically beneficial for them to descore 4+ pins from their own alliance goal. This goal descored had a mix of yellow and blue pins scored on it (this was noted by the head referee). The unpenalized final score would be 103 blue to 56 red. There are no other relevant interactions in the match by either alliance that would call for an application of <SG9>, <SG10>, or any other penalizing rule.
<SG9> notes that opponent alliance goals are protected, with no mention of anything relating to non-opponent alliance goals, so <SG9> seems irrelevant here.
<SG10> notes that removing (directly or indirectly) game pieces from neutral goals has the potential to be a major violation. However this rule is about neutral goals, not an alliance's own alliance goals, so it also seems not applicable here.
There seems to be no other even moderately relevant rules to the legality of this decision by the blue alliance.
Would it be correct in this scenario to keep the final score as 103 blue to 56 red, and award blue the victory and advance them to the next round of the elimination bracket (assuming this is match R16 2-1)? If not, why? Are there any grounds in this scenario that would call for a disqualification?
Thank you for your time!
  • Red Robots are allowed to remove any and all Scoring Objects from red Alliance Goals.
  • Blue Robots are allowed to remove any and all Scoring Objects from blue Alliance Goals.
This remains true regardless of Pin color/Ownership.
3250: <SG10> Removal of Momentarily Placed Scoring Object
21-Sep-2026
SG10
<SG10> <SC2>
In the 2.0 manual, SC2 Placed Scoring Object criteria a. A Pin is considered Placed if it meets all of the following criteria: i. The Pin is partially or entirely nested with a Goal, or with a Cup that is partially or entirely nested with another Placed Pin. ii. Each Goal and/or each half of a Cup nested with that Pin contains a maximum of one Pin half. (See Figure SC2-2.) b. A Cup is considered Placed if it meets the following criteria: i. The Cup is partially or entirely nested with a Placed Pin.
It is very common to see a robot holding a pin together with a cup in a claw. The robot tries to put this combination on another pin already in a goal. As they attempt to add these scoring objects, the pin on the goal is partially contained within the inner volume of the Cup. The robot then tries to open the claw, but fails (or is slightly misaligned) as they back away and those scoring objects fall to the tiles, but were at one point breaking an imaginary plane at the opening of a Cup.
Should that be counted as a score/descore and, possibly, match affecting considerations? Or simply just an unsuccessful scoring attempt in this interaction since it only broke the plane momentarily?
You describe a scenario in which a Robot attempts to Place additional Scoring Objects on a neutral Goal, which become momentarily Placed before falling off due to some fault of the Robot (such as misalignment, jerky movement, etc.).
This kind of scenario should be treated as an unsuccessful attempt to Place additional Scoring Objects, not as a removal of Placed Scoring Objects. Although these Scoring Objects were momentarily Placed, applying <SG10> here would be overly punitive and is not the intent of the rule.
However, if the Robot also removes any Scoring Objects that were already Placed on the Goal before this attempt, that would still be a Violation of <SG10>.
3270: SG10 — Classification of Cup-only removals in Head-to-Head and Robot Skills Matches
9-Oct-2026
SG10
Dear GDC, We have reviewed Q&A 3153(d), which confirms that removing a Placed Cup from a neutral Goal violates <SG10> regardless of its effect on the score. We seek clarification on violation classification in the following scenarios. In each scenario, a Cup was already Placed on the uppermost Placed Pin of a neutral Goal before the interaction. There are no Scoring Objects above the Cup. Only the Cup is removed; all Pins and other Cups remain in their existing positions. Scenario A: The Cup’s transparent half faces downward. The Robot deliberately removes it to expose the Pin beneath it and make subsequent stacking easier. Scenario B: The same deliberate action occurs with the Cup’s opaque half facing downward, exposing the previously covered Pin Half. Scenario C: During an otherwise legal stacking attempt, the Robot accidentally dislodges the previously Placed Cup. Please consider both Cup orientations. Assume this is an isolated, unintentional interaction.
  1. In Head-to-Head Matches, should Scenarios A and B both be classified as Major Violations under <SG10> Violation Note 2, even when only one Cup is removed and no immediate scoring benefit occurs?
  2. For Scenario C, how should Match Affecting be evaluated when only a Cup is removed, given that the numerical calculations in <SG10> Violation Note 1 address removed Pins?
  3. In Driving Skills Matches and Autonomous Coding Skills Matches, where the Robot previously Placed the Cup during the same run, does Violation Note 2 independently make Scenarios A and B Major Violations, even without a net increase in the final score?
  4. For Scenario C in Robot Skills, how should “score affecting” under <RSC1> be evaluated when removing the Cup either exposes a scoring Pin Half or facilitates additional scoring later in the run? Thank you for your clarification.<SG10>
  1. The accidental removal of one Placed Cup from a neutral Goal during an otherwise legal stacking attempt would typically result in a Minor Violation. Here's why:
  • <SG10> Violation note 1 covers Match Affecting calculations with a focus only on Pins removed, which does not apply here. (As mentioned in Q&A 3232, we felt that it would be too difficult to consistently track details such as which color Pins were visible or hidden in the stack, which is why we decided that Match Affecting calculations would disregard removed Cups and involve only removed Pins.)
  • <SG10> Violation note 2 covers intentional, strategic, or egregious Violation, which also does not apply here.
  • Per <SG10> Violation note 3, a Team that has repeatedly committed <SG10> Minor Violations over the course of a Match/event could see this Violation escalate to a Major Violation at the Head Referee’s discretion. If this were only an isolated incident, Violation note 3 would not apply.
  1. Match Affecting calculations do not apply to <SG10> Violations that only involve the removal of a Placed Cup.
  2. Per <RSC2.e>, Robots can add or remove Pins or Cups on all Goals. <SG9> and <SG10> do not apply in Robot Skills Matches.
  3. Per <RSC2.e>, Robots can add or remove Pins or Cups on all Goals. <SG9> and <SG10> do not apply in Robot Skills Matches.
3161: Position of Alliance Station with reference to loader position.
7-Jun-2026
SG11
<SG11>
[Example Image]
The Driver's Station appears to be about a foot from the field and a foot from the end of the field. It would be difficult for a drive team member to stay in the driver's station as drawn and interact with the loader as intended. Are Event Partners allowed to change the Driver's Station so that it is against the field and goes to the end of the field?
Thanks!
The Alliance Station tape lines, as depicted in the Game Manual, are not intended to represent exact dimensions or positioning relative to the rest of the field.
We do not provide exact dimensions or positioning for the Alliance Stations since they are typically not critical to gameplay, which provides EPs more leeway when taping off these areas. However, these tape lines should always be placed such that Drive Team Members can reasonably view and interact with the Field from within the Alliance Station during a Match, so the tape lines should extend far enough for Drive Team Members to reach the Loaders with relative ease.
We recognize that this is not made clear in the game manual, so we're planning to incorporate this guidance in the July 2 game manual update.
3164: Match Load Placement Clarification
16-Jun-2026
SG11
<SG11>
In rule SG11 it states "introduce' refers to the moment when a Drive Team Member has released a Scoring Object into a Loader." However, point b of SG11 states "A Match Load Scoring Object may not be contacted by a Robot prior to being introduced into a Loader." Since the only definition of matchloading is when someone releases a game object into a loader, is it legal for a robot to be sitting under a raised loader and a driveteam member releasing a game object into the loader and it falls directly into the robot without it first touching the ground?
Yes, it is legal for a Scoring Object released into a Loader to fall directly into the Robot. There is no requirement for Match Load Scoring Objects to contact the Floor after being introduced.
3196: Does SG11a forbid match loading during auto skills?
4-Aug-2026
SG11
<SG11> SG11a states that "scoring objects may only be introduced...during the Driver Controlled Period of a match". The definition of match in Appendix B defines "Autonomous Coding Skills Matches" as matches with "no Driver Controlled Period". My interpretation of is rule is that, when read together with the definition, it forbids match-loading during Autonomous Skills Matches.
However, at some events it has been ruled that teams are allowed to introduce match loads during Autonomous Skills Matches. Whilst the rules seem fairly clear, because of the potential impact of this ruling (especially if it were to be applied inconsistently between competitions) I wanted to ensure that it was clarified.
Therefore: Does SG11a forbid introducing match loads during Autonomous Skills Matches?
Teams may introduce Match Load Scoring Objects at any time during a Robot Skills Match, but only through red Alliance Loaders. This applies to both Driving Skills Matches and Autonomous Coding Skills Matches.
<RSC2>clause D will be revised in the August 6 game manual update to make this more clear.
3235: Match Loading questions
15-Sep-2026
SG11
Our team is testing a few method of loading and wanted to know if the following two methods are legal ways to load:
  1. Loader is lifted up, pin and cup loaded onto the field, set the loader down so that it now sits on part of the pin when released, acting like a way to hold the objects.
  2. Loader is lifted up, loader places a cup and pin from the back of it to sit on the floor, but the pin is placed on the floor far enough, that it sits outside of the loader when it is closed.
So the two questions being asked, can the loader be in contact with game elements after being loaded and is there a requirement that the game objects loaded be within the volume of the loader once the load is complete?
<SG11>
There are no rules that prohibit these example scenarios.
  1. Can the Loader be in contact with Scoring Objects after being loaded?
Yes.
  1. Is there a requirement for Scoring Objects to be fully within the volume of the Loader once the load is complete?
No.
3254: Matchloading Clarification
26-Sep-2026
SG11
Is there rule dictating when or under what circumstances the human player on a drive team is allowed to lift up the matchloader to put a game element in in? For example, does the robot have to be within the protected Load Zone for the drive team member to lift the matchloader to put a game element in? Or can the human player keep the matchloader held up at all times?
[Example Image]
For V5RC Matches, Drive Team Members can only operate (raise & lower) their Alliance-colored Loaders during the Driver Controlled Period of the Match. (We will clarify this in the October 8 game manual update.)
Other than that, there are no rules that dictate when or how long a Drive Team Member is allowed to raise the Loader during a Match.
3260: Match loading - momentary contact SG11c
6-Oct-2026
SG11
<SG11> Does momentary contact allow a team to hold a pin steady in place while the robot grabs it, where they time their release so it is "momentary", assuming this could be completed safely and without extending any part of the hand below the edge of the loader. For example, could a team hold a pin suspended off the surface inside the original volume of the match loader so they are positioning it at the correct height for their robot mechanism, and then release it as the robot essentially grabs it out of their hand? Or, can the team member push the pin/cup into the waiting robot's loading mechanism below the raised loader? Additionally, if these are not legal, could you clarify a type situation in which momentary contact could legally occur?
Yes, that is a perfect example of allowed momentary contact.
If the team member is lowering the Pin/Cup down into the Loader and waits until the Pin/Cup makes contact with the Robot before releasing the Pin/Cup, that would be another perfect example of allowed momentary contact.
If instead the team member is taking time during the Match Loading process to position the Pin/Cup within the Robot (e.g., pushing the Pin/Cup fully within an intake mechanism, repositioning the Pin/Cup within the Robot, or holding the Pin/Cup until securely held within a claw's grip), this would likely involve more than momentary contact, which would result in an <SG11> Violation.
We ask that Teams and Head Referees use common sense (<G3>) when interpreting "momentary contact", and we would advise Teams to be reasonable and avoid pushing the bounds of this interpretation. It is in everyone's best interest if Head Referees are allowed to spend most of the Match watching for more significant rule violations (e.g., <SG9> and <SG10>), rather than watching for minor Match Loading violations.
3231: Clarification of protected Load Zones
13-Sep-2026
SG13
SG13 states that alliance load zones are protected during the driver period. The load zones are marked with tape. The intent of the rule is to protect Load Zoness from intentional interference by the opposing alliance.
  1. Can an opposing robot park in front of the load zone if it does not break the 3-D plane of the tape, and thus prevent access to the load zone?
  2. While a robot is match loading, an opposing robot pushes into it and causes the pin/cup to topple over at the bottom of the loader. The opposing robot backs off, and then repeats the offense when the robot tries to match load again. Would this count as separate minor violations of the same rule, or a singular minor violation of SG13 for the match? Would repeat offenses within the same match be considered a major violation?
Yes.
  1. While a robot is match loading, an opposing robot pushes into it and causes the pin/cup to topple over at the bottom of the loader. The opposing robot backs off, and then repeats the offense when the robot tries to match load again. Would this count as separate minor violations of the same rule, or a singular minor violation of SG13 for the match? Would repeat offenses within the same match be considered a major violation?
Each offense would count as a separate <SG13> Minor Violation, or as a Major Violation if the offense was determined to be egregious. Repeat <SG13> Minor Violations may escalate to a Major Violation at the Head Referee's discretion. (When contemplating escalation to a Major Violation, Head Referees should consider the context of the Violations within a Match. Repeat Violations involving incidental/inconsequential interactions likely do not warrant escalation to a Major Violation in most cases.)
3247: Combination of Minor Violations, Escalation to Major Violation, and Precedence of Major Violations
21-Sep-2026
SG9 SG13
After a match, a team argued that their opponents had committed the following actions in a match:
  1. The opponents had repeatedly incidentally contacted their alliance goal without knocking any elements off of the alliance goal, thereby not changing the score of the match. <SG9> defines this as a moment of interaction between the robot and opponent alliance goal.
  2. The opponents had pushed them once into their own matchloader in the game momentarily, which could be seen as a violation of <SG13>.
We ask the following questions:
  1. Do the repeated incidental contacts between a team and opposing alliance goals without any game elements being knocked down escalate to a major violation at any defined point?
  2. Does the incidental pushing of an alliance robot into their own matchloader by their opponents count as a major or minor violation? How can this be decided?
  3. Should the violations described in parts (1) and (2) be combined for a greater/major violation, or should they be considered separately as separate violations in a match?
  4. The team which had argued that these incidents occurred in the match had definitely committed a major violation during the match. How are referees to resolve this match in elimination rounds; a double disqualification, or only a disqualification for the team which had more Major Violations/the stronger case for having committed a Major Violation?
Thank you!
There is no defined point at which repeat Minor Violations escalate to a Major Violation; the Head Referee must determine if an escalation is warranted based on the context of the Match(es), including the actions of the Robot and the consequences of those actions. If a Robot commits two or three inconsequential Minor Violations, that Robot likely does not deserve a Major Violation for those repeat Minors. Escalation of repeat Minors to a Major Violation should typically be reserved for more consequential violations, or for violations committed with a blatant disregard for the rules and/or disregard for Head Referee warnings.
  1. Does the incidental pushing of an alliance robot into their own matchloader by their opponents count as a major or minor violation? How can this be decided?
A single incidental SG13 violation would typically be considered a Minor Violation. Repeat SG13 violations may escalate to a Major Violation at the discretion of the Head Referee, especially if there have been prior warnings to cease this behavior or if this repeat behavior appears to be intentional. Any single SG13 violation could also be considered a Major Violation if it was deemed by the Head Referee to be an egregious violation. For example, prolonged contact (interference) with a protected Robot in its Load Zone could be deemed egregious and deserving of a Major Violation by the Head Referee.
  1. Should the violations described in parts (1) and (2) be combined for a greater/major violation, or should they be considered separately as separate violations in a match?
They should be considered separately. Any violation notes that mention the possibility of repeat Minor Violations escalating to a Major Violation are referring to repeat violations of the same rule, such as a Robot that commits multiple SG13 Minor Violations. Committing multiple Minor Violations across different rules, such as one SG9 Minor Violation and one SG13 Minor Violation, would not count as repeat Minor Violations in this way.
  1. The team which had argued that these incidents occurred in the match had definitely committed a major violation during the match. How are referees to resolve this match in elimination rounds; a double disqualification, or only a disqualification for the team which had more Major Violations/the stronger case for having committed a Major Violation?
If an Elimination Match results in both Alliances receiving at least one Major Violation each, the result will be a double disqualification, and the Match must be replayed to determine which Alliance will advance. It does not matter if one Alliance has 2, 3, or more Major Violations while the other Alliance only has 1 Major Violation; the result is still a double disqualification.
3275: sg9 and sg13 Violation
13-Oct-2026
SG9 SG13
Per these rules a robot that is accepting a load from a match loader can not be touched. And the Robot can not be touched when it is scoring on the alliance color. Those 2 areas are one robot turn from each other. The last tournament no one was scoring on the black they were just scoring on their color because they can not be touched at both locations. My question can the robot be pushed out while transitioning from the match loader to his alliance color stacking. If not something needs to change because their is no defense that can stop that.
Attempting to play defense on an opposing Alliance Robot moving back and forth between their protected Alliance-colored Goals and their nearby protected Load Zone is an extremely risky move that will likely result in committing <SG9> and/or <SG13> Violations.
It's not impossible to play defense around opposing Alliance-colored Goals/Load Zones, but these rules are intended to heavily discourage that. If you don't want to risk incurring those Violations, stay away from those areas of the Field, especially the corner containing the two opposing Alliance-colored Goals and one of their Load Zones.
3170: SG4(a) - Clarification on removal of deflected game objects
23-Jun-2026
SG4
<SG4>
When preparing to referee/score-keep a scrimmage recently, I came across a particular scenario regarding clause A of <SG4>. The first sentence of Clause A states:
If a Scoring Object is leaving the Field (as determined by the Head Referee), but is deflected back into the Field by a Drive Team Member, field monitor, ceiling/wall, or other external factor, it should still be considered "out of the Field" and removed by a Scorekeeper Referee or Head Referee.
My question regarding this clause is if the game element in question does indeed leave the field, as determined by the Head Referee, and is deflected back into the field via an external factor, but comes to rest in a hard to reach area such as close to or within the midfield (emphasis mine):
A) Are the Scorekeepers or Head Referee still expected to reach into the field during a match to attempt to remove the game element and reintroduce it back as described in main body of <SG4>?
B) If Yes to A, then how would this be applied to raised fields where mobility to reach into the field is already extremely limited to roughly the first tile or two from the perimeter wall?
C) If No to A, since the objective of the game does not involve any form of tossing or launching of the game elements, would this be left as a Minor/Major Violation ruling based on the listed violation notes and/or a violation of <GG4>, Hands out of the Field, as listed in the latter sentence of Clause A?
I would appreciate the GDCs clarification in proceeding given such a scenario. Thank you!
Note: In version 1.0 of the game manual, <SG4> has been updated such that Scoring Objects that have been deflected back into the Field are no longer considered "out of the Field."
A) No. There is no need to remove these Scoring Objects since they are no longer considered "out of the Field."
B) N/A
C) In the event a Scoring Object is leaving the Field but gets deflected back into the Field by a Drive Team Member, it would most likely be considered incidental contact and would not result in a <GG4> Violation. It would only result in a <GG4> Violation if the contact was deemed to be intentional.
3166: SG6 - Clarification on Possession vs Plowing
18-Jun-2026
SG6
<SG6>
SG6 limits Possession to a maximum of one (1) Pin and one (1) Cup, and SG6a clarifies that Plowing multiple Scoring Objects is permitted.
Appendix B defines Possession as a status where "a Robot's change in direction would result in controlled movement of the Scoring Object," typically requires at least one of the following:
  • the object is fully supported
  • moved in a preferred direction inside a concave face...
  • held against the Floor or a Field Element.
Plowing is defined as intentionally moving an object in a preferred direction with a flat or convex face or with another Scoring Object (emphasis mine).
Consider a stack consisting of several Pins and Cups. A Robot uses a concave mechanism such as a claw, to grab a single Scoring Object at the bottom of that stack. The bottom cup or pin is contacting the robot and meets the definition of possession, however the remaining pins and cups only meet the first dot point, and is "moving with another Scoring Object."
Is the Robot considered to be Possessing only the single Scoring Object it has directly grasped, with the remaining stacked objects treated as plowed? Or, because the Robot's change in direction results in controlled movement of every object in the stack, is the Robot considered to be Possessing all of those Pins and Cups placing it in Violation of SG6 once the count exceeds one Pin and/or one Cup?
If a Robot picks up a stack of Pins and Cups by grabbing only the bottom Scoring Object in that stack, the Robot's change in direction would result in controlled movement of every Scoring Object in that stack. Therefore, the Robot is considered to be in Possession of every Scoring Object in that stack, and the Robot would incur an <SG6> Violation if this results in Possessing more than one Pin and/or more than one Cup.
3190: Clarification on Plowing vs. Possession
21-Jul-2026
SG6
Our robot features a structure at the rear of the chassis consisting of a High Strength Shaft with two standoffs mounted on either side, creating a slightly concave/U-shaped profile. There is a Polycarbonate shaped like the diagram installed between the two standoffs, which sits nearly flush with the field, making it impossible to scoop or lift any Pins or Cups. Rule <SG6a> states: "Plowing multiple Scoring Objects is permitted. Teams which employ Plowing strategies are encouraged to clearly demonstrate that none of the Scoring Objects are being Possessed, e.g., by using a flat face of the Robot with no active mechanisms."
Q1. Would pushing multiple Pins and/or Cups along the floor using this rear structure be considered legal Plowing, or would this concave shape be viewed as "Possession" (or carrying/holding) of those Scoring Objects?
Q2. Does using a passive concave boundary (like two standoffs with the PC sheet) automatically constitute Possession, or is it evaluated strictly based on whether the objects are trapped, lifted, or actively controlled?
[Example Image]
The definition of Possession was revised in the September 3 game manual update, and it no longer matters whether a Robot's face is flat, convex, or concave when determining Possession of Scoring Objects.
Using the pictured example of your Robot's rear structure, driving backward and pushing Scoring Objects within this rear structure would result in controlled movement of Scoring Objects, but driving forward would result in losing control of those Scoring Objects. Since your Robot's movement in all directions would not result in maintained control of the Scoring Objects (and none of the Scoring Objects would be fully supported by your Robot), pushing Scoring Objects using this rear structure would not be considered Possession.
3191: Clarification of apparent conflicting Autonomous rules in <SG7>
21-Jul-2026
SG7
Rule <SG7> (b) states:
Scoring Objects that begin the Match in contact with the Autonomous Line are not considered to be on either side, and may be utilized by either Alliance during the Autonomous Period...
and <SG7> (e):
Contact with either of the following during the Autonomous Period will result in the Autonomous Bonus and an Autonomous Win Point being awarded to the opposing Alliance, unless the opposing Alliance also breaks rules in the Autonomous Period: i. An opponent Robot that isn’t interacting with the Autonomous Line, objects that begin the Match positioned above or in contact with the Autonomous Line, or the Midfield (see <SG8>). ii. Scoring Objects on the other side of the Autonomous Line.
I am curious about the clause in (e).(i) that includes "..objects that begin the match positions above or in contact with the autonomous line.." stating that they are banned from use during autonomous and will result in both the autonomous bonus and win point awarded to the opposing alliance. The problem arises as: (b) is clarifying exactly what objects are considered to be "in contact" with the autonomous line, and that they are allowed to be used (e) is saying that objects "in contact" with the autonomous line are banned from use.
Would the GDC be able to clarify: A. Which ruling is intended to be correct, and in the case (b) is correct, any potential intent of including such clause in (e): such as banning other objects from use that may not be covered by (b)? B. If (e).(i) is correct in that those objects are unable to be contacted, does ".., or the midfield" mean objects that start on the midfield, or the midfield's lines and vertical projection itself?
There is no conflict between <SG7> clauses B and E. There's a misinterpretation of SG7.e.i here, so let's break that down.
SG7.e states the consequences for contacting two specific things during the Autonomous Period: (i) an opposing Robot that isn't interacting with certain objects/locations and (ii) Scoring Objects that are on the other side of the Autonomous Line. If we narrow our focus down to SG7.e.i, it is calling out contact with an opposing Robot that isn't interacting with three particular locations/objects.
We can read SG7.e.i in a different way, which should make things a bit more clear:
i. An opposing Robot that (1) isn't interacting with the Autonomous Line, (2) isn't interacting with objects that begin the Match on the Autonomous Line, and (3) isn't interacting with the Midfield.
We acknowledge that the current wording/formatting of SG7.e.i lends itself to misinterpretation, so we'll attempt to make this more clear in the next game manual update.
3262: SG7e Violation Clarification
6-Oct-2026
SG7
<SG7>
I was with a few other Head Refs discussing the game and we wanted to clarify the Violation Notes for SG7e -- specifically, Violation Notice 2 states "...or the interactions described in <SG7e> will be considered Major Violations and should result in a Disqualification for the Match."
Last year, the loss of the Auton Bonus and AWP was the only penalty for violating this section. However, with the new notes, it appears there is an additional penalty and that we should be DQ'ing a team any time SG7e happens during Autonomous. This seems overly punitive for an Auton mistake and leaves that team with no reason to continue the match after the first 20 seconds. Is this the correct interpretation of this rule and violation note?
The interactions described in <SG7e> are not automatically Major Violations. Violation Note 2 of <SG7> applies only to Violations that are intentional, strategic, or egregious.
If contact described in <SG7e> is accidental or incidental, it is a Minor Violation. The opposing Alliance receives the Autonomous Bonus and Autonomous Win Point (unless they also committed a Violation during the Autonomous Period), per <SG7e> and <SG7> Violation Note 1.
If contact described in <SG7e> is determined by the Head Referee to be intentional, strategic, or egregious, it is a Major Violation and should result in a Disqualification for the Match, per <SG7> Violation Note 2.
3245: SG9 Violation Notes
21-Sep-2026
SG9
<SG9>
In the 2.0 manual, Alliance Goals are protected, violation notes: "Intentional, strategic, or egregious interactions, including any interactions involving the addition or removal of Placed Scoring Objects on the Goal, will be considered Major Violations.
Does this mean that ONLY interactions involving the addition or removal of Placed Scoring Objects on the Goal that are intentional, strategic, or egregious are Major Violations (where the clause starting with "including..." acts as a clarifying example of the types of interactions being evaluated and does not strip away the core conditions (intentional, strategic, or egregious) that define whether the interaction rises to a Major Violation.)? Or does this mean that all interactions involving the addition or removal of Placed Scoring Objects on the Goal are also a major violation?
In the next game manual update, <SG9> violation note #2 will be revised to clarify our intent. This should read as:
  1. Intentional, strategic, or egregious interactions, as well as any interactions involving the addition or removal of Placed Scoring Objects on the Goal, will be considered Major Violations.
Any interaction by a Robot that causes the addition or removal of Placed Scoring Objects on an opposing Alliance-colored Goal will result in a Major Violation, regardless of intent.
3138: Substituting Colored Field Tape for White Tape
14-May-2026
T6
<T6> states (emphasis mine):
Fields may be repaired at the Event Partner’s discretion. All competition Fields at an event must be set up in accordance with the specifications in Appendix A and/or other applicable Sections. Minor aesthetic customizations or repairs are permitted, provided that they do not impact gameplay (see <T4>).
An example of a permissible modification to the Field listed in the rule is:
Using non-VEX electrical tape to add required lines to the Field
Would substituing the red and blue tape lines that define the Load Zones with white tape lines be a permissible modification to the Field?
Note: This answer was revised on July 2, 2026.
Following the addition of SG13 Load Zone protections in the July 2 game manual update, using white tape lines in place of red/blue tape lines for the Load Zones is no longer a permissible Field modification under <T6>.
Event Partners must use red and blue tape lines for the Load Zones to denote which Alliance they belong to. This helps referees identify SG13 violations that may occur involving Robots in and around opposing Alliance Load Zones.
