<RSC6>
Starting an Autonomous Coding Skills Match. Drivers must start a Robot’s Autonomous Coding Skills Match routine by pressing a button on the Robot Brain or manually activating a sensor. Because there is no VEX IQ Controller hand-off, only one (1) Driver is required for an Autonomous Coding Skills Match (though Teams may still have two (2) if desired).• Pre-Match sensor calibration is considered part of the standard pre-Match setup time (i.e., the time when the Team would typically be turning on the Robot, moving any mechanisms to their desired legal start position, etc.).
• Pressing a button on the VEX IQ Controller to begin the routine is not permitted. To avoid any confusion, Teams are advised not to bring controllers to Autonomous Coding Skills Matches.
In accordance with <GG3>, Teams should be mindful of event schedules and set their Robot up as promptly as possible. The definition of “prompt” is at the discretion of the Event Partner and Head Referee, and could depend on things like how much time is left for the Skills Challenge Field(s) to be open, how many Teams are waiting in line, etc. As a general guideline, three seconds to calibrate a Gyro Sensor would be acceptable, but three minutes to debug a program would not.
