<SG5>
Each Robot gets one Pin as a Preload. For Teamwork Challenge Matches, the Team listed as Team 1 (printed Match list) or Red Team (RobotEvents.com) will use a red Pin. Team 2 / Blue Team will use a blue Pin. Prior to the start of each Match, each Preload must be placed such that it meets all of the following criteria:• Contacting exactly one Robot.
• Not contacting any Field Elements (excluding the Floor), Goals, or other Scoring Objects. If a Robot is not present for a Teamwork Match, its Preload should be placed in the matching Load Zone.
Significant Q&As:
• Q&A 2869 - Preloads are required, not optional
