<R16>
Pneumatics. Robots using parts from the VEX IQ Pneumatics Kit (228-8795) must satisfy all of the following criteria:• No more than two Air Tanks, including any that aren’t connected.
• No more than one Air Pump, including any that aren’t connected.
• No additional parts that are not included in the VEX IQ Pneumatics Kit (e.g., unofficial tubing or fittings).
• Teams may not use other elements for the purposes of storing or generating air pressure, and cannot use Pneumatic Cylinders or additional tubing solely for additional air storage. Robots are limited to the air pressure stored in two Air Tanks, as well as the normal working air pressure contained in any Pneumatic Cylinders and tubing on the Robot.
• Teams can only use Pneumatic Cylinders and/or tubing as part of an actual pneumatic system (e.g., Air Tanks and/or an Air Pump). There is no limit on the number of Pneumatic Cylinders or Pneumatic Solenoids that may be used, provided that no other rules are violated. There are no restrictions on running the Air Pump prior to (or during) Matches.
