<R20>
A limited amount of tape is allowed. Robots may use a small amount of tape for the following purposes: To secure any connection between the ends of two (2) VEX cables. To label wires and motors. To cover the backs of license plates (i.e., hiding the “wrong color”). To prevent leaks on the threaded portions of pneumatic fittings. This is the only acceptable use of Teflon tape. In any other application that would be considered a “non-functional decoration” per <R9>. As an aglet at the end of rope/string to prevent fraying.
