<R22>
A limited amount of tape is allowed. Robots may use a small amount of tape for the following purposes:• To secure any connection between the ends of two (2) VEX cables.
• To label wires and motors.
• To prevent leaks on the threaded portions of pneumatic fittings. This is the only acceptable use of Teflon tape.
• In any other application that would be considered a “non-functional decoration” per <R24>.
• As an aglet at the end of rope/string to prevent fraying.
