<R5>
Robots must fit within an 18” x 18” x 18” volume.• Compliance with this rule may be checked using the
• Event Partners may construct and/or provide any sizing tool that measures the correct dimensions.
• Any restraints used to maintain starting size (i.e., zip ties, rubber bands, etc.) must remain attached to the Robot for the duration of the Match, per <GG8>.
• For the purposes of this rule, it can be assumed that Robots will be inspected and begin each Match on a flat standard foam field tile.
The official sizing tool is intentionally manufactured with a slightly oversized tolerance. Therefore, any contact with the sizing tool (i.e., a “paper test”) while being measured should be considered a clear indication that a Robot is outside of the permitted size. This tolerance also provides a slight “leeway” for minor protrusions, such as screw heads or zip ties. Other tools, such as custom sizing boxes or the legacy non-expanding VEX Sizing Tool (276-2086), may be used for informal checks. However, in the event of a conflict or “close call,” a check with the official On-Field Robot Expansion Sizing Tool takes precedence.
This rule is applied differently for VEX U. See Rule <VUR1>.
