<RSC2>
Scoring Robot Skills Matches. For each Robot Skills Match, Teams are awarded a score based on the following rules and scoring table:• Teams will receive points for all Scored Blocks, regardless of color. A Block is not considered Scored if it is in contact with a Robot at the end of the Match.
• A Control Zone is considered filled if it ends the Match containing its maximum number of Scored Blocks, and if all Blocks in that Control Zone are the same color (e.g., all are blue, or all are red). In a Robot Skills Match, a Center Goal Control Zone must contain at least seven (7) Blocks to be considered filled. A Long Goal must include one or more of the following to be considered filled in a Robot Skills Match: Three Blocks of the same color fully contained between the inner edges of the Control Zone tape lines. Four Blocks of the same color fully contained between the outer edges of the Control Zone tape lines.
• The Team will earn points for a cleared Park Zone if no Blocks are in contact with the Floor inside the Park Zone at the end of the Match.
• The Team will earn points for a cleared Loader if no Blocks are within that Loader at the end of the Match.
• The Team will earn points for a Parked Robot if the Robot has moved during the Match, is within the red Alliance Park Zone, and meets all criteria of rule <SC4> at the end of the Match.
Each Block Scored in a Goal
1 Point
Each filled Control Zone in a Long Goal
5 Points
Each filled Control Zone in a Center Goal
10 Points
Each Cleared Park Zone
5 Points
Each Cleared Loader
5 Points
Parked Robot
15 Points
Significant Q&As:
• Q&A 2903 - Any movement in or of the Robot counts as having moved during the Match
