<RSC3>
Robot and Field setup for Skills Matches. The Robot and Field are set up the same as for a Head-to-Head Match (e.g., the Robot must meet the requirements of <SG1>), with the following modifications:• In Autonomous Coding Skills Matches, the VEX GPS code strip must be installed on the Field.
• The Robot must start the Robot Skills Match in a legal starting position for the red Alliance.
• All Drive Team Members must remain in the red Alliance Station for the duration of the Match.
• One red Block must be used as a Preload in accordance with <SG5>.
• Revised Block layout. 36 Blocks begin the Match in unscored positions on the Field and 24 Blocks begin in the Loaders, as shown in Figure RSC3-1.
• Robots may move freely about the Field after the start of the Match.
• Robot Skills Matches do not include Match Load Blocks. This rule is applied differently for VEX U. See Rules <VURS1>, <VURS2> & <VURS3>.
