<SG2>
Horizontal expansion is limited. Once the Match begins, Robots may expand horizontally beyond the 18” x 18” starting size limit within the following criteria:• The Robot can never be larger than 22” wide or 22” long (must always be able to fit within a 22”x22” square horizontal footprint). Violation Notes:
• The primary intent of this rule is to limit Defensive horizontal expansion. As such, Robots that expand horizontally in the vicinity of multiple Goals may be subject to rule <GG15>, and will not receive the “benefit of the doubt” in the case of any Head Referee judgment calls.
• Incidental/insignificant infractions that occur during a Match are only considered Minor Violations. Repeated Minor Violations should only escalate to a Major Violation in extreme circumstances. Examples of Minor Violations include, but are not limited to: Loose wires Broken zip ties / rubber bands Bent or broken mechanical components that are not used for strategic gain This rule is applied differently for VEX U. See Rule <VUG2>
