<SG5>
Each Robot gets one Block as a Preload. Prior to the start of each Match, each Preload must be placed such that it meets all of the following criteria:• Contacting one Robot of the same Alliance color as the Preload.
• Not contacting the same Robot as another Preload.
• Not contacting or within the volume of a Goal or Loader. Note: If a Robot is not present for their Match, then that Robot’s Preload may be used as a Match Load in accordance with <SG9>.
Violation Notes: See <SG1>.
