<R21>
A limited amount of tape is allowed. Robots may use a small amount of tape for the following purposes:• To secure any connection between the ends of two (2) VEX cables.
• To label wires, motors, Robot Brains, and/or controllers.
• To prevent leaks on the threaded portions of pneumatic fittings. This is the only acceptable use of Teflon tape.
• In any other application that would be considered a “decoration” per <R23>.
• As an aglet at the end of rope/string to prevent fraying.
