<R26>
The VEX Pressure Gauge (276-8748) is a required part if a Robot includes pneumatics.• The gauge must be plumbed to the high pressure side of the system if the Team is using a regulator.
• The pressure gauge must be visible and readable by referees and inspectors without moving or removing other Robot components or mechanisms.
• The pressure gauge will be used to verify that the pneumatics system is charged to no more than 100psi, per <R25>. The VEX Pressure Gauge on the Robot will take precedence over any off-board measurement.
