<RSC4>
Field setup for Skills Matches. The Field is set up differently than a Head-to-Head Match, with the following modifications:• In Autonomous Coding Skills Matches, the VEX GPS code strip must be installed on the Field.
• Revised Match Loads. Three (3) red/yellow Pins, four (4) blue/yellow Pins, and seven (7) Cups begin off the Field as Match Loads.
• All Goals start the Match empty with no Placed Pins. This rule is applied differently for VEX U. See Rule <VURS1>.
Figure RSC4-1: An overhead view of a V5RC Override Robot Skills Match.
