<SG5>
Each Robot gets one Pin as a Preload. Red Alliance Preloads are red/yellow Pins; blue Alliance Preloads are blue/yellow Pins. Prior to the start of each Match, each Preload must be placed such that it meets all of the following criteria:
• Contacting one Robot of the same Alliance color as the Preload.
• Not contacting the same Preload as another Robot.
• Not contacting other Scoring Objects.
• Not contacting any other Goals, Loaders, Load Zones, or Toggles. Note: If a Robot is not present for their Match, then that Robot’s Preload may be used as a Match Load in accordance with <SG11>. Violation Notes: See <SG1>.
Game Rules Index
