<RSC2>
The Team may utilize fourteen (14) Match Load Discs, within the guidelines set forth by <SG6>. Seven (7) Match Load Discs begin the Match in each Alliance Station, just as in a Head-to-Head Match. Match Load Discs must be introduced from the Alliance Station in which they begin the Match. At any point during the Match, one (1) Drive Team Member is permitted to move between the two (2) Alliance Stations for the purpose of introducing Match Load Discs. There may never be more than one (1) Drive Team Member outside of the Alliance Station in which the Team began the Match. Note: This rule applies to both Driving Skills Matches and Programming Skills Matches.
