Skip to Main Content
This Q&A is now read-only
Official Q&A: VRC 2018-2019: Turning Point
22: Other Questions
30047A
7-Jun-2018
Can a team extend tabs from their robot which extend out over the edges of the center platform to keep them on when an opponent is attempting to push them off? This is assuming they do not grapple the platform in any capacity, so they don't "exert force or pressure on opposite sides of an object to control its position."
Can a team use a potential energy based series of actions which begins as time runs out, enabling them to score or descore after time has expired?
Answered by Game Design Committee
Please review the Q&A Usage Guidelines before posting, specifically points 3 (quote the applicable rule), 4 (make a separate post for different questions), and 5 (use specific and appropriate question titles).
  • Can a team extend tabs from their robot which extend out over the edges of the center platform to keep them on when an opponent is attempting to push them off? This is assuming they do not grapple the platform in any capacity, so they don't "exert force or pressure on opposite sides of an object to control its position."
It sounds like you're referring to SG10, quoted here for reference:
<SG10> Don’t clamp your Robot to the field. Robots may not intentionally grasp, grapple or attach to any Field Elements, including the Platforms. Strategies with mechanisms that react against multiple sides of a Field Element in an effort to latch or clamp onto said Field Element are prohibited. The intent of this rule is to prevent Teams from both unintentionally damaging the field and/or from anchoring themselves to the field.
It is impossible to provide a blanket ruling on a hypothetical design. However, a static mechanism which extended past the edge of the Center Platform and did not clamp or anchor the robot to it would likely not violate this rule. A mechanism which reacted against multiple sides of the Center Platform, anchoring or latching the Robot to it, would likely violate this rule.
Of course, this assumes that no other rules, such as SG2, are violated in the process.
  • Can a team use a potential energy based series of actions which begins as time runs out, enabling them to score or descore after time has expired?
Please see G16, quoted here for reference:
<G16> It’s not over until it’s over. Scores will be calculated for all Matches immediately after the Match, once all Game Objects, Field Elements, and Robots on the field come to rest.
Provided that no Robot or Safety rules were violated, there are no rules prohibiting this, and the scores would be calculated once all robots and game objects have come to rest. That said, please remember G2 - "common sense always applies in the VEX Robotics Competition".
