Skip to Main Content
This Q&A is now read-only
Official Q&A: VRC 2019-2020: Tower Takeover
446: <SG2> Indirectly contacting opponent tiles, cubes via cube
UWAT
9-Dec-2019
<SG2> Stay on your side in Autonomous. During the Autonomous Period, Robots may not contact the foam tiles, Towers, or Cubes which are on the opposing Alliance’s side of the Autonomous Line.
Violations of this rule will result in the Autonomous Bonus being awarded to the opposing Alliance. Intentional, strategic, or egregious violations, such as intentional contact with an opposing Robot while completely across the Autonomous Line, will result in a Disqualification.
Note: Towers and Cubes which begin the Match in contact with the Autonomous Line are not considered to be on either side, and may be utilized by either Alliance during the Autonomous Period. If attempting to utilize these Towers or Cubes, Teams should be cognizant of the possibility that opponent Robots may attempt to do the same. <SG7>, <G10>, <G11>, and <G12> will be taken into account when these types of Robot interactions occur.
<SG7> Use Cubes to play the game. Cubes may not be used to accomplish actions that would be otherwise illegal if they were attempted by Robot mechanisms. Examples include (but are not limited to):
• Encroaching upon an opponent’s Protected Zone per <SG3>.
• Interfering with an opponent’s Autonomous Period per <SG2>.
a. According to QA 405, https://events.vex.com/VEXU/2019-2020/QA/405 "violations could range from the Autonomous Bonus being awarded to the opposing Alliance, to a Disqualification, depending on the context of the interaction." Does this mean that if a cube has cross the autonomous line from red into the blue side, either unintentional or intentional, then that red alliance automatically lost autonomous bonus, since the word from is used?
b. If the robot is intaking a neutral cube(started contacting the autonomous line), then the second the robot touched the cube, the robot now has indirectly contacted the foam tile in opposing alliance. According to SG2 Note, cubes "may be utilized by either Alliance during the Autonomous Period." In this case, does this note take precedence over SG2 via SG7?
Answered by Game Design Committee
As noted in the Q&A that you linked, causing Cubes to interact with foam tiles, Towers, or Cubes on the opposing Alliance's side of the Autonomous Line would be considered a violation of SG2 via SG7. Interaction with foam tiles, regardless of whether it affects a Robot's autonomous routine or not, is always considered a violation of SG2. As you quoted, all violations of SG2 result in the Autonomous Bonus being awarded to the opposing Alliance. Intentional, strategic, or egregious violations, such as intentional contact with an opposing Robot while completely across the Autonomous Line, will result in a Disqualification.
Yes.
When evaluating a possible violation of either of these cases, we would advise Teams and Head Referees to bear in mind rule G3 - "please remember that common sense always applies in the VEX Robotics Competition."
