Official Q&A: VRC 2019-2020: Tower Takeover
452: <G12> How to determine if incidental entanglement is egregious
<G12> Don’t destroy other Robots. But, be prepared to encounter defense. Strategies aimed solely at the destruction, damage, tipping over, or Entanglement of opposing Robots are not part of the ethos of the VEX Robotics Competition and are not allowed. If the tipping, Entanglement, or damage is ruled to be intentional or egregious, the offending Team may be Disqualified from that Match. Repeated offenses could result in Disqualification from the entirety of the competition. b. VEX Robotics Competition Tower Takeover is an interactive game. Some incidental tipping, Entanglement, and damage may occur as a part of normal gameplay without violation. It will be up to the Head Referee’s discretion whether the interaction was incidental or intentional.
<R3> Robots must be safe. The following types of mechanisms and components are NOT allowed: c. Those that pose an unnecessary risk of Entanglement.
<G13> Offensive Robots get the “benefit of the doubt”. In the case where referees are forced to make a judgment call regarding a destructive interaction between a defensive and offensive Robot, or an interaction which results in a questionable rules violation, the referees will err on the side of the offensive Robot.
Egregious is not defined in the game manual, by Oxford Dictionary https://www.oxfordlearnersdictionaries.com/us/definition/english/egregious
extremely bad
the definition of extremely
to a very high degree
extremely is a very subjective adjective, how should one determine if the incidental tipping is egregious? Does the duration of the entanglement(usually starts from the time of entanglement to the end of the game) matter? Does the scoring capability of the robots that are entangled matter(how much points would they score if they are not entangled)? Does the context when the entanglement happened(whether the robot was playing defense or offense) matter? Does R3 come into play as well, and we need to determine whether there was unnecessary risk of entanglement?
Two reference videos:
https://youtu.be/AGJUpDCF0nQ?t=25953
at 7:12:33 the blue robot was playing defense and has entangled with the red robot. Red won the match so the entanglement is not match affecting.
https://youtu.be/EXhWerDR03w?t=187
at 3:07 the red robot was playing defense and has entangled with the blue robot. Red was DQed for that match, I couldn't find any other violations in this game other than the entanglement, so I believe red is DQed for "egregious entanglement" since it was not intentional.
As you noted, this is a very subjective question. If it was possible to provide a black-and-white definition, then human Head Referees would not be necessary. It is the judgment and discretion of these Head Referees which determines if a given interaction is egregious or not.
We are not going to be able to provide a point-by-point checklist to determine where to draw this line. The answer to all of your specific questions is, "it could". In general, we would provide the following overarching guidelines:
Context matters. As noted in this similar Q&A, if a game is played more defensively at a different event, then it would stand to reason that the judgment calls would be handled differently in the context of that event.
Offense vs defense matters. Per G13, offensive Robots usually get the "benefit of the doubt".
On-field performance of the tipped/Entangled/damaged Robot generally does not matter. This is why G12 is one of the only rules in the Game Manual that does not hinge upon Match Affecting verbiage, and instead uses "egregious".
