Skip to Main Content
This Q&A is now read-only
Official Q&A: VRC 2020-2021: Change Up
738: Tetherbots and R1
2344B
29-Jan-2021
A team has a main robot and a tethered minibot. For skills matches the team disconnects the minibot and uses only the main robot. Is this a violation of rule R1, specifically R1c?
R1c states "Teams may not switch back and forth between multiple Robots during a competition. This includes using different Robots for Skills Challenge, Qualification and/or Elimination Matches"
R1
Answered by Game Design Committee
The Subsystem definitions in R1 read as follows:
• Subsystem 1: Mobile robotic base including wheels, tracks, legs, or any other mechanism that allows the Robot to navigate the majority of the flat playing field surface. For a stationary Robot, the robotic base without wheels would be considered Subsystem 1.
• Subsystem 2: Power and control system that includes a legal VEX battery, a legal VEX control system, and associated motors for the mobile robotic base.
• Subsystem 3: Additional mechanisms (and associated motors) that allow manipulation of game objects or navigation of field obstacles
Given the above definitions, a minimum Robot for use in any VEX Robotics Competition event (including Skills Challenges) must consist of 1 and 2 above. Thus, if you are swapping out an entire subsystem of either item 1 or 2, you have now created a second Robot and are no longer legal.
It is always difficult to provide a blanket answer based on a snapshot description of a hypothetical design. For this to be legal, inspectors and Head Referees should make the following decisions:
  1. If the "minibot" portion of your Robot is not considered Subsystem 1 or Subsystem 2 of your Robot (i.e. it is not the "mobile robotic base").
  2. If Subsystems 1 and 2 are not swapped out when changing between configurations.
If these conditions are met, and the "minibot" can therefore be interpreted as Subsystem 3, then this would be a legal configuration change. At this point, the Robot would be subject to R3, which discusses Robots with multiple functional configurations.
<R3> Robots must pass inspection. Every Robot will be required to pass a full inspection before being cleared to compete. This inspection will ensure that all robot rules and regulations are met. Initial inspections will take place during team registration/practice time.
a. Significant changes to a Robot, such as a partial or full swap of Subsystem 3, must be re-inspected before the Robot may compete again.
b. All possible functional Robot configurations must be inspected before being used in competition.
