Skip to Main Content
This Q&A is now read-only
The Official Q and A is now closed. If you want to submit a question for the Worlds Drivers Meeting, please click here. The deadline for question submission is Friday, March 24.
Official Q&A: VRC 2022-2023: Spin Up
1245: <SG6> and the legality of introducing match load disks in different orientations
81988E
19-Oct-2022
<SG6> states:
Match Load Discs must be introduced by a Drive Team Member placing them gently onto a Loader.
The intent of this rule is to permit Teams to impart enough energy on Match Load Discs such that they slide onto the tile (or a Robot) directly in front of the Loader. “Throwing,” “rolling,” or otherwise imparting enough energy onto the Discs such that they leave the intended tile, or violate one of the other points in this rule, is not permitted.
Would it be legal to introduce match load disks such that they do not lay flat on the loaders? For example, please consider this picture here: [Example Image] If there were a robot with an adequate mechanism to "catch" the disk in front of the loader, it would certainly not leave the intended tile. Would this way of introducing match loads be legal as long as the disk does not leave the intended tile?
Answered by committee
No. Per <SG6b>, "See Figure 22 [of the Spin Up game manual] for examples of how Match Load Discs should be introduced." Discs should be laid flat on the Loader and pushed or pulled into the field.
Further, <SG6bi> specifies that Discs should "slide onto the tile (or a Robot) directly in front of the Loader." Introducing a Match Load vertically, as shown in your question, is considered rolling rather than sliding.
