This Q&A is now read-only
The Official Q and A is now closed. If you want to submit a question for the Worlds Drivers Meeting, please click here. The deadline for question submission is Friday, March 24.
Official Q&A: VRC 2022-2023: Spin Up
1271: definition of diameter of string for expansion
in R7e it states that : An unlimited amount of rope / string, with a thickness / diameter between 1/8” (3.175mm) and 1/4” (6.35mm).
The definition of Diameter is stated as:
- a straight line passing from side to side through the center of a body or figure, especially a circle or sphere.
Would a cord or rope with the dimensions of 1.5mm and 5mm which be considered legal? The cord has a diameter between 1/8" and 1/4" but is also flat.
Thank you for your question. Rule <R7e> will be revised in the next Game Manual update to indicate that other than length, every measurement of string must between 1/8"/3mm and 1/4", regardless of the shape of the string. For example, a flattened string would be legal only if it is at least 1/8"/3mm thick and no more than 1/4" wide.
