This Q&A is now read-only
The Official Q and A is now closed. If you want to submit a question for the Worlds Drivers Meeting, please click here. The deadline for question submission is Friday, March 24.
Official Q&A: VRC 2022-2023: Spin Up
1335: Versa Hub Adapters
Under rule R6 it states that no VEX Pro parts are to be used. I am asking about Versa Hub Adapters that teams are using Part 217-8079 and 217-2592. They pull up as pro parts on VEX website. I also found the Vex library article that says they are legal. Here is that link: https://kb.vex.com/hc/en-us/articles/10487034781076-Flex-Wheels-for-V5. The section I found it on is the parts substitution. I am hosting a tournament tomorrow and the question is: Are the versa hub adapters listed above legal for VRC game play? Thank you for your time.
Thank you for your question, and for pointing out this omission. The following VEX VersaHub product listings are legal for use in the VRC competition, as included on this page of the VEX website:
- 1.125” Bearing Bore Plastic VersaHub Spacer (1/2” Wide); SKU#: 217-2591
- 1/2” Hex Bore Aluminum VersaHub; SKU#: 217-2592
- 1.125" Bearing Pilot Plastic VersaHub (1/4" Wide, w/ Plate Sprocket Mount); SKU#: 217-3234 (Discontinued)
- 1/2” Hex Bore Plastic VersaHub; SKU#: 217-4009 (Discontinued)
- 1/2” Hex Bore Plastic VersaHub v2; SKU#: 217-8079
Rule <R6> will be revised to reflect this in the next Game Manual update.
