This Q&A is now read-only
The Official Q and A is now closed. If you want to submit a question for the Worlds Drivers Meeting, please click here. The deadline for question submission is Friday, March 24.
Official Q&A: VRC 2022-2023: Spin Up
1363: T23 Mixed Field Types
<T23> There are two types of Field Perimeter that may be used:
- VEX Metal Competition Field Perimeter (SKU 278-1501)
- VEX Portable Competition Field Perimeter (SKU 276-8242) See Appendix A for more details. If an event has multiple fields, then all fields of the same game type must use the same Field Perimeter type, in accordance with <T21> and <RSC6>. For example, it would be permissible for Head-to-Head competition fields to use metal Field Perimeters, and for Skills Challenge fields to use Portable Field Perimeters. However, it would not be permissible for one Head-to-Head field to use a metal Field Perimeter, while other Head-to-Head fields use Portable Field Perimeters.
At our next event we are running two Metal fields for head-to-head matches, and two Portable field for skills. During breaks we would like to allow the Metal qualification fields to be used for skills at a team's discretion - all four fields would be available to give skills more capacity.
Would this be an allowable exception?
As noted in <RSC6>, all Skills Challenge fields at a single event must use the same type of field control and field perimeter.
In order to use non-conforming Head-to-Head fields for Skills Challenge runs (e.g., during lunch), the following steps should be taken:
Teams must be informed that the Head-to-Head Fields may have some differences from the Skills Challenge Fields (e.g., they might not have the GPS strips)
Teams must be given an option to select which type of Field they want to use, i.e. they cannot be required to use the Head-to-Head Field for any Skills Challenge run
