This Q&A is now read-only
The Official Q and A is now closed. If you want to submit a question for the Worlds Drivers Meeting, please click here. The deadline for question submission is Friday, March 24.
Official Q&A: VRC 2022-2023: Spin Up
1468: Latex Tubing as rope/string
<R7> Certain non-VEX components are allowed. Robots are allowed the following additional “non-VEX” components: e. An unlimited amount of rope / string, with a thickness / diameter between 1/8” (3.175mm) and 1/4” (6.35mm).
For purposes of this rule, would latex tubing be considered rope/string? I recognize that even if it is not, 5' sections of it purchased from Vex would be legal to use for endgame but would longer sections of latex tubing with an outside diameter of 1/8 inch be legal to use under this rule?
Clause E of <R7> states that Robots may include, "An unlimited amount of non-elastic rope / string, with a thickness / diameter between 1/8” (imperial standard) / 3mm (metric standard) and 1/4” (6.35mm). String must measure at least 1/8” / 3mm in diameter at its narrowest point while on the Robot under no load."
<R7e> does not permit the use of non-VEX latex tubing as rope or string.
