This Q&A is Read Only.
Official Q&A: VRC 2023-2024: Over Under
1561: Definition of Possession
<SC1> Before rules, the definition of "Possession" seems impossible. It awkwardly tries to allow very limited forms of pushing (plowing isn't really an appropriate word). It talks about changing the direction of motion of the tribal, implying that a blade cannot cause lateral motion. In fact pushing on the left and then on the right (through steering) has the same effect as a a curved blade. I suspect the intent is to say "When only one triball in contact with the robot at any time, but excludes a robot with a stationary straight blade pushing one or more triball(s)."
After thought.... by current definition, you can only REMOVE one triball from a net at a time <SG8>. My initial thought was a sweep, but that is controlling more than one triball at a time. What is the intent of the game? How do you incorporate removal into "Possession" definition?
The definition of "Possession" should not be interpreted any differently when referring to interactions with Triballs that are Scored in Goals.
Regarding the other comments, please be sure to review the Q&A Usage Guidelines before posting, specifically note 1, "The Q&A system is for rules clarifications only". As noted, the Q&A platform is intended to be a communication channel for questions such as "is this interpretation of a rule legal?", not a discussion forum to post questions such as "I disagree with this rule, can it be changed". For those comments, please use the official VEX Forum or email [email protected].
