This Q&A is Read Only.
Official Q&A: VRC 2023-2024: Over Under
1780: Question regarding possession and concave spaces
<SG7>So according to the game manual, possession is defined as: "A Robot / Triball status. A Robot is considered to be Possessing a Triball if a Robot’s change in direction would result in controlled movement of the Triball. This typically requires at least one of the following to be true: The Triball is fully supported by the Robot. The Robot is moving the Triball in a preferred direction with a concave face of the Robot (or inside of a concave angle formed by multiple mechanisms/faces of the Robot)."
So it is my understanding that if a robot has two triballs in a concave surface, but only one changes direction with the robot that the robot is possessing only one triball. Here is a video demonstrating what I mean:https://www.youtube.com/watch?v=y4hdsG4raAE Is my understanding of the rule correct?
This interaction would likely fall into the "gray area" that is explained in this related Q&A post.
Remember that during a Match, a Head Referee won't be asking for a stable, isolated demonstration of a snapshot moment in time, such as the linked video. They will watch a Robot driving around the field, interacting with multiple Triballs, and make a judgment whether the Robot appeared to be Possessing any of them or simply Plowing through them.
The Note at the end of SG7 is also worth bearing in mind:
Note: There are no rules prohibiting Plowing multiple Triballs. However, Robots which employ Plowing strategies should be cognizant of any accidental Possession risks while doing so, such as a Triball rolling into an intake mechanism while another one is already there.
