Skip to Main Content
This Q&A is Read Only.
Official Q&A: VRC 2023-2024: Over Under
1838: SG6 - single triball at a time with 2 alliance match load zones?
Eric Schnurr
19-Dec-2023
As a follow up Q&A 1789: https://events.vex.com/VRC/2023-2024/QA/1789
Does the 1 triball limit apply only to a single match load zone (IE 1 corner)? Or does it apply to both alliance match load zones jointly (IE 2 corners)?
Thank you for your time and consideration. Eric Schnurr
Answered by committee
21-Dec-2023
Q&A 1778, which first introduced the concept of a "one Triball at a time" rule, states the following (bolding added for emphasis):
Any interaction where two Triballs are being held past the plane of the field wall (at the same Match Load Zone)
Note 2 of <SG6> is only intended to refer to actions taken at the same Match Load Bar / Zone. Simultaneous Match Loading at two separate Match Load Zones is fine.
