Skip to Main Content
This Q&A is Read Only.
Official Q&A: VRC 2023-2024: Over Under
1904: One Preload must be placed per <SG4> in skills
1065A
28-Jan-2024
In RSC2, One Preload must be placed per <SG4> in skills. It says clearly the word "MUST". However, in SG4, If a Team does not wish to use their Preloads, or if a Robot is not present for their Match, then the Preloads may be used as Match Load Triball. So I am confused whether both the two red balls in skills can be used as match load, or one of them must be placed on the field. Thanks.<RSC2>
Answered by committee
7-Feb-2024
In Robot Skills Matches, both Preload Triballs can be used as Match Loads if the Team wishes to do so.
The relevant portions of <RSC2> and <SG4> read as follows:
<RSC2> [...] c. Teams may use the two (2) red Alliance Preloads as follows: i. One Preload must be placed per <SG4>. ii. The second red Alliance Triball may be placed in any non-scored position in the Blue Offensive Zone and not touching the Robot, or may be used as a Match Load per <SG6> and <RSC3>.
<SG4> [...] If a Team does not wish to use their Preloads, or if a Robot is not present for their Match, then the Preloads may be used as Match Load Triballs in accordance with <SG6>.
The first Triball can be thought of as "the normal Preload", and must abide by all portions of <SG4>. This includes the portion which gives the option to use it as a Match Load instead. The second Triball can be thought of as "the extra Skills Preload", and must abide by the separate criteria listed in <RSC2>.
