Skip to Main Content
The official VEX V5 Robotics Competition Question & Answer system has closed for this season.
Official Q&A: VEX V5 Robotics Competition 2024-2025: High Stakes
2139: SG9 and Defense
Dylan Schmit
16-Sep-2024
<SG9><SC7>
SG9a states:
a. If the two Robots are not at the same Level, the higher Robot has the “right of way.” i. Point A especially applies if one Robot is not Climbing, i.e., is still in contact with the Floor. Driving directly into a Climbing Robot will always incur a Minor Violation at a minimum, even if no damage occurs.
Does “Climbing” in SG9ai refer to the criteria for “Climbed to a Level” defined by SC7? For example, RED1 is attempting to climb and BLUE1 is on the ground trying to defend them. Is it legal for a BLUE1 to drive into RED1 to stop them from climbing if RED1 is touching the ladder but still contacting the tiles? If not, what criteria should referees use to determine when a robot starts “climbing”?
Answered by committee
19-Sep-2024
Thank you for your question, and for allowing us to clarify the intent of rule <SG9>. The definition of Climb will be revised as follows in the next game manual update, and this change is effective immediately.
Climb - A Robot action. A Robot is considered to be Climbing if it has intentionally grasped, grabbed, or attached itself to the bottom/black rung of the Ladder and/or a higher point of the Ladder. In most cases, this means a Robot mechanism will be reacting against multiple sides of a rung or vertical section in an effort to latch, clamp, or hook onto the Ladder. See <SC7> for the criteria for a Robot to be considered to have Climbed to a Level.
As stated in Clause Ai of rule <SG9>, "Driving directly into a Climbing Robot will always incur a Minor Violation at a minimum, even if no damage occurs."
