The official VEX V5 Robotics Competition Question & Answer system has closed for this season.
Official Q&A: VEX V5 Robotics Competition 2024-2025: High Stakes
2151: SG6, clarification on "egregious or clearly intentional"
Possession is limited to two Rings and one Mobile Goal. Robots may not have Possession of more than two (2) Rings at once. Robots may not have Possession of more than (1) Mobile Goal at once. Robots in Violation of this rule must immediately stop all actions except for attempting to remove the excess Scoring Objects. If they are unable to remove the excess Scoring Objects, then they must return to a legal starting position (as described by <SG1>). They will not be eligible to receive points for Climbing. Any offensive or defensive interactions with Mobile Goals, Stakes, and Corners will be included in Match Affecting calculations.
- Rings on a Stake are not included in a Robot’s Possession count. For the purposes of this rule, “on a Stake” means that the Ring meets the criteria for a Scored Ring, even if it is being contacted by a Robot.
- Plowing multiple Mobile Goals is permitted. However, Plowing an additional Mobile Goal while also Possessing one is considered a Violation of this rule due to the extremely high likelihood of accidental/implied Possession. Teams which employ Plowing strategies are encouraged to clearly demonstrate that none of the Mobile Goals are being Possessed, e.g., by using a flat face of the Robot with no active mechanisms.
Violation Notes: Any egregious or clearly intentional Violation by an Alliance who wins the Match will be considered a Major Violation. Examples of “clearly intentional” Violations include, but are not limited to:
- Possessing two or more Mobile Goals in a single Corner.
- Continuing to play other portions of the game (e.g., defensive maneuvers, Climbing) without returning to a starting position for the majority of the Match.
- “Accidentally” Possessing an egregious amount of opponent Rings.
- Possessing six Rings, and Scoring them onto one Stake with a single action.
- “Removing excess Scoring Objects” directly into Placed/Scored states.
Scenario: While Possessing a Mobile Goal, a red robot Plows an additional Mobile Goal which has some rings scored on it. As a result, the Plowed Mobile Goal becomes Placed in a Corner.
Would this violation of SG6 be considered "egregious or clearly intentional", and thus be a Major Violation if red wins the match, no matter the score? Or would the violation only escalate to a Major if it is determined to be Match Affecting?
Thank you!
Your scenario falls under the 5th bullet in the Violation Notes for <SG6>:
If an Alliance wins the Match after committing an egregious or clearly intentional <SG6> Violation, they should receive a Major Violation and Disqualification regardless of the point difference of the Match (i.e, whether it's Match Affecting or not).
