Skip to Main Content
The official VEX V5 Robotics Competition Question & Answer system has closed for this season.
Official Q&A: VEX V5 Robotics Competition 2024-2025: High Stakes
2290: Metal String Usage Clarification
2130X
12-Nov-2024
Rule <R8e> states "An unlimited amount of rope/string, no thicker than 1/4” (6.35 mm)" is legal. My questions are:
  1. Is metal string permissible under this definition?
  2. Are accessories specifically for metal string, such as ferrules, metal wire thimbles, and wire rope clips, allowed for use in conjunction with metal string?
Best regards, 2130X
R8
Answered by committee
14-Nov-2024
The game manual does not provide a definition of "string." We're not going to provide one here, either. Instead, we'll point you to the 4th paragraph in Section 3 of the game manual:
Most of these rules are “hard limits,” such as the maximum number of motors permitted. However, some are “at inspector discretion,” such as determining a mechanism’s potential safety risk. At many events, the lead inspector and the Head Referee are the same person; if they are not, then the volunteer inspector should confirm any questionable judgment calls with the Head Referee. The Head Referee has final authority regarding all Robot rules, since it is ultimately their decision whether a Robot takes the field for a Match after inspection has concluded (per <R3d> and <R3e>).
Regarding string, a material used on a Robot is string if the inspector and Head Referee at the event both agree that it's string. Some examples (fishing line, paracord, twine) would reasonably be considered string by most or all inspectors and referees. Others (dowel, pneumatic tubing, chain) would not (see rule <G3>). A few, including metal, would require judgment calls by the inspector and Head Referee based on how the material is used on the Robot, and opinions are likely to differ between events.
  1. Are accessories specifically for metal string, such as ferrules, metal wire thimbles, and wire rope clips, allowed for use in conjunction with metal string?
No.
