Skip to Main Content
The official VEX V5 Robotics Competition Question & Answer system has closed for this season.
Official Q&A: VEX V5 Robotics Competition 2024-2025: High Stakes
2296: spacers and washers for high-strength shafts
90504R
13-Nov-2024
<R21>
<R21> was recently updated to add M2.5 x 8mm screws (as used in the low-profile high-strength shaft collars). However, it does not explicitly mention spacers or washers for the HS shafts, with an approximate inner diameter of 5/16".
Q&A 2091 approved the use of M5 spacers, though not mentioned in <R21>, provided they add no functionality. Does the same apply to spacers and washers for the HS shafts? (These could be fabricated from approved parts, so there doesn't appear to be any added functionality.)
Thank you.
Answered by committee
21-Nov-2024
There are no legal, commercially-available replacements for washers and spacers that fit the VEX V5 high strength shafts.
