Skip to Main Content
The official VEX V5 Robotics Competition Question & Answer system has closed for this season.
Official Q&A: VEX V5 Robotics Competition 2024-2025: High Stakes
2426: Strategic use of R3
Susan OConnor
10-Jan-2025
<G1>, <G3>, <R3>, <T5>, <T6>, Code of Conduct
If a team notices a problem with another team’s robot, which would likely cause that team to fail a ‘spot inspection’, do they have an obligation to report that information in a timely manner? Or could they wait until it is strategically advantageous to do so?
Example: During qualification matches, Team A noticed that Team B’s robot brain placement probably should not have passed inspection. Fixing the problem would have taken considerable time. Rather than approaching Team B and letting them know so they could fix their robot proactively, or informing the Head Referee directly, Team A waited until they were about to face Team B in a semi-final elimination match before pointing out the problem to the Head Referee.
Should Team B be allowed to play their match since they’ve played through all the qualification matches and it’s at the Head Referee’s discretion whether to conduct spot inspections? Or should their robot be removed from the field per R3, T5 & T6. Has Team A violated G1, G3, or the Code of Conduct?
Answered by committee
23-Jan-2025
We believe that this scenario falls under rule <G1>, "Treat everyone with respect." If you see anyone breaking a rule at a Match Field, you should immediately bring it to the Head Referee's attention and let them handle it as they deem appropriate. If you see a Violation away from the Field, you should alert the Event Partner. Teams must use extreme caution when handling these situations, and should remember to remain respectful, civil, truthful, and professional. Once the matter has been reported to the Head Referee or the Event Partner, their decisions and ruling will be final as described in rules <T1> and <T4>.
If a Head Referee believes a Team is reporting potential Robot rule Violations strategically, maliciously, or speculatively, it should be treated as a <G1> Violation and immediately brought to the attention of the Event Partner who should then consult with the REC Foundation Regional Support Manager as described in the Violation Notes for <G1>.
If a Team's Robot is found to be in Violation of a Robot rule during an event, rule <R3> (specifically clauses C, D, & E) will apply.
In the specific case you describe, in which a Team believes another Team's Robot Brain is in an unsafe location, Head Referees must apply judgment to determine whether or not the reported Team should be allowed to continue without modifying the Robot.
