This Q&A is now read-only
Official Q&A: VEX V5 Robotics Competition 2025-2026: Push Back
2677: Custom Cut Plastic/Metal Generated from Outside the Team - G4, R2, R25
The GDC ruled on this for High Stakes but since Q&As don’t carry over from year to year, I would like an official ruling on this, please.
Scenario: students find on-line (or are given by another team or an adult) a CAD file for a set of custom cut plastic parts for their robot and use it to cut plastic for their robot.
Is this a violation of G4/R2? If so, would the legality of the parts change if the students credited the source of the files in their notebook and/or to the inspection team?
Would it be a violation of G4/R2 if the students found (or were given) the CAD file, printed it on paper, taped it to the plastic then followed the pattern manually, cutting the plastic with tin snips or a band saw?
Is it a violation of G4/R2 if the students find and use (unchanged) a piece of custom cut plastic or metal made and discarded by another team?
Relevant rules: G4: The Robot must represent the skill level of the Team. R2: Robots must represent the Team’s skill level. The Robot must be designed, built, and programmed by members of the Team. R25: Robots may use custom-made pieces cut from certain types of non-shattering plastic, up to 0.070” thick. d. Plastic may be mechanically altered by cutting, drilling, bending, etc. Thank you!
Yes. These parts were not designed by members of the Team, which is a requirement of rule R2. If the parts were designed by a Student from another Team, that Student has effectively served as a Designer for multiple Teams in the season, which is a violation of rule G4. If the parts were designed by an Adult, it is a violation of rule G2.
No.
Yes.
Yes.
