Skip to Main Content
This Q&A is now read-only
Official Q&A: VEX V5 Robotics Competition 2025-2026: Push Back
2732: <RSC4> Can teams end a Skills Match early for any other reason than to record a Skills Stop Time
Susan OConnor
23-Jul-2025
<RSC4>
During robot skills matches teams often opt to end their skills match early if continuing may damage their robot or there’s a problem with a sensor that would make continuing pointless (literally and figuratively).
At a recent event, a field tech asked the Event Partner to inform teams they could end their match early ONLY if they had informed the scorekeeper they would be recording a Skills Stop Time. The field tech wanted to reduce the number of early-aborted matches logged in the field’s V5 Robot Brain, to make it easier for himself to determine if aborted matches were due to field faults. The Event Partner instructed that teams had to allow the timer (and thus their robots due to the method of field control being used at the event) to continue if they had not discussed a Skills Stop Time in advance. This was frustrating to teams and could have resulted in damage to students’ robots, particularly if autonomous codes went awry. After discussion with a Head Referee, the decision was reversed and teams were again allowed to end their matches early, though a Skills Stop Time was only recorded if they’d discussed it in advance with the Scorekeeper at the field, as described in <RSC4>.
Can teams elect to end a Skills Match early for a reason other than recording a Skills Stop Time or does this scenario fall under <T4> The Event Partner has ultimate authority regarding all non-gameplay decisions during an event?
Answered by committee
30-Jul-2025
Can teams elect to end a Skills Match early for a reason other than recording a Skills Stop Time or does this scenario fall under T4 The Event Partner has ultimate authority regarding all non-gameplay decisions during an event?
Teams can only end a skills Match using the process described in rule <RSC4>, and only if the Scorekeeper Referee has been notified before that Match. If a Team has a concern about Robot safety and believes that there is any chance they'll want to end the Match early, they should prearrange a Stop Time signal for that Match.
Because Skills Stop Time is a gameplay decision, rule <T4> does not apply and the rule must be followed as described in the game manual.
