This Q&A is now read-only
Official Q&A: VEX V5 Robotics Competition 2025-2026: Push Back
2969: <GG9> <GG15> <GG17> <SG10> Priority Call for a Head Referee
Good Evening GDC,
After some discussion, we are looking to determine if a Head Referee should focus first on an < SG10 > violation or on a potential hold < GG17 > of the robot committing the < SG10 > violation.
For an example:
- RED1 goes to descore a goal and inserts its arm into the open section as allowed, with no current violations of < SG10 >
- With the new definitions of defensive and offensive on 12/4, RED1 becomes defensive ("descoring in a way that doesn't increase points for the Robot's own Alliance")
- BLUE1 goes over to prevent the descore of the blocks in the goal
- RED1 has their arm still in the open section of the goal and claims that they are being held "pinned" by BLUE1 (in this instance, they no longer are actively moving blocks in the goal, thus they are now goalkeeping)
If RED1 were to remove their arm from the open portion of the goal, a hold count would be started instantly in this situation because it is clear to the Head Referee that RED1 wants to leave the area now, rather than stay there and continue descoring objects.
If RED1 is not actively moving blocks, they are in violation of < SG10 > and need to remove their arm from the goal immediately as they are goalkeeping.
The question becomes is should a hold count be started by the Head Referee immediately when this situation occurs, or should RED1 remove their arm from the goal first to remedy the < SG10 > violation?
The assumption is that the < SG10 > violation should be resolved first due to RED1 above being the defensive robot, getting no "benefit of the doubt" from < GG15 >, as written in < SG10a >.
Thank you for your time, Cowboy
In your scenario, BLUE1 is playing more Defensively than RED1 (BLUE1 is making no attempt to move Blocks), so the Holding should be considered before any possible Goalkeeping.
RED1 is reaching into the Goal and actively moving blocks, and BLUE1 moves in to hold them. A Holding count should begin immediately. BLUE1 can legally hold RED1 for a 3-count before they must separate.
If BLUE1 backs off after a 3-count, and RED1 removes their arm from the Goal when they're able, neither Robot should get a Violation.
If BLUE1 continues Holding beyond a 3-count, they should get a <GG17> Violation.
If RED1 is Goalkeeping after blue departs, RED1 should get an <SG10> Violation.
