Skip to Main Content
This Q&A is now read-only
Official Q&A: VEX V5 Robotics Competition 2025-2026: Push Back
3002: Pushing Robots Around the Field
37167H
20-Dec-2025
According to rule <GG17>, teams are not allowed to Hold other Robots for more than a 3 count. Does pushing Robots around the field count as Holding, and would it count towards a penalty?
The definition of Holding includes Trapping, Pinning, and Lifting.
Trapping is "Limiting the movement of an opponent Robot to a small or confined area of the Field, approximately the size of one foam field tile or less, without an avenue for escape." This does not apply in this scenario as the pushed Robot would be moving outside of a space approximately the size of one foam tile.
Lifting is "Controlling an opponent's movements by raising or tilting the opponent's Robot off of the foam tiles.” This also does not apply, as the Robot getting pushed will just slide across the Floor and not get tilted or raised.
Pinning is the only one left, and it is not as clear whether or not this one counts. It says "Preventing the movement of an opponent Robot through contact with the Field Perimeter, a Field Element, or another Robot." Under the definition of a Field Element is the Field. The Field consists of the Floor. The definition of the Floor includes all the foam tiles. In the case of pushing, this rule could be interpreted as preventing the individual free will movement of an opponent Robot using [Foam Tiles], which in this case would be considered Pinning.
Even if this is considered Holding, In rule <GG17b>, it says that a way for the Holding count to pause is if "Either Robot has moved at least two (2) feet away (approximately one tile) from the location where the Trapping or Pinning count began." This will be fulfilled when the pushing Robot moves with the pushed Robot more than two feet away from the starting point of contact. So would pushing of any kind (That does not tip a Robot) be completely legal? If not, here are some scenarios that might differ in that answer:
(All these scenarios are different and might change the legality of pushing based on rule <GG15> which states that "Offensive Robots get the "benefit of the doubt.""
Scenario 1: RED1 is trying to score on a goal, when BLUE1 pushes them more than two feet out of the way to stop them
Scenario 2: RED1 is sitting at the end of a goal attempting to prevent the BLUE team from scoring, but BLUE1 pushes RED1 more than two feet away and goes to score.
Scenario 3: RED1 is scoring at a goal, and BLUE1 is coming up to them to push them out of the way. RED2 then pushes BLUE1 more than two feet away to stop them from being defensive and preventing their ally from scoring.
None of these scenarios are match affecting.
What is the legality of these scenarios, what would be the penalty for all of these, and will the rules change to change the previous two answers or not?
Answered by committee
8-Jan-2026
There is no rule that prohibits pushing another Robot if the interaction doesn't lead to intentional damage, tipping, or Entanglement (<GG14>) or the definitions of Trapping, Lifting, or Pinning (<GG17>). Pushing a Robot across the foam tiles does not count as Pinning them to those tiles (<G3>).
The gameplay described in all of your scenarios is legal, and none of the Teams should be penalized.
And no, we do not intend to change the rules to make pushing illegal.
