Skip to Main Content
This Q&A is now read-only
Official Q&A: VEX V5 Robotics Competition 2025-2026: Push Back
3114: Clarification to question 2787, GG4
Nathan Blair (Event Partner)
28-Feb-2026
In question 2787 it was determined that blocks that are within tolerance should not be adjusted. If a team does make adjustments is that considered a violation? (Major, Minor, DQ) How should it be ruled?
GG4  T5
Answered by committee
5-Mar-2026
Because rule <GG4> does not have specific Violation notes, the guidance in Figure V-2 applies. The Team should receive a Minor Violation unless the Head Referee determines that the Violation was Match Affecting or the Team has already received multiple <GG4> Violations.
The case you describe, in which the Team reaches into the Field to adjust object positions before the Match begins, probably isn't Match Affecting, and the Head Referee should consider re-adjusting all affected Scoring Objects before the Match begins.
