This Q&A is Read Only.
Official Q&A: VIQRC 2023-2024: Full Volume
1504: Robot Size
<G5> Robots begin the Match in the starting size. At the beginning of a Match, each Robot must fit within an 11” wide x 20” long x 15” high (279mm x 483mm x 381mm) volume, as checked during inspection per <R4>.
20inch = 508mm
Is the size of the robot for the 2023-2024 Full Volume either 19 inches or 20 inches?
Answered by committee
Thank you for pointing out this discrepancy in size. Rule G5 will be revised with correct metric limitations (279mm x 508mm x 381mm) in the next game manual update.
