The official VEX IQ Robotics Competition Question & Answer system has closed for this season.
Official Q&A: VEX IQ Robotics Competition 2024-2025: Rapid Relay
2209: Switches becoming Un-Cleared During the Game
Per <SC4> a switch is cleared once it has been struck by a ball and is no longer parallel with the front face of the goal wall. If a switch is cleared and then through normal game play the switch returns to the uncleared position where it remains till the end of the match, per <SC1> scoring statuses are evaluated after the match ends should the switch be evaluated based on the final position, even though <SC7>states that rapid relay is designed to be scored in real time.
Example: A ball becomes wedged in the switch, without fully passing through the target, holding the switch in a partially flipped position. The ball is later dislodged by a robot and falls back into the field, which causes the switch to return to its starting position, and is untouched till the end of the match.
How should cleared switches be scored with respect to <SC1> and <SC7>?
